Trying to connect MyEnergi Hub requiring port 87 to be open
- Trying to connect MyEnergi Hub requiring port 87 t...
06-09-2023 6:21 PM
Re: Trying to connect MyEnergi Hub requiring port 87 to be open
06-09-2023 6:35 PM
@MAXDRAXX it says nothing about that in the instructions - https://www.myenergi.com/wiki/hub/hub_overview/
Have you updated to the latest firmware?
06-09-2023 6:48 PM
been told by MyEnergi that port 87 needs to be open
@MAXDRAXX it only needs to be open for outgoing connections. All ports are open for outgoing connections
06-09-2023 6:52 PM
06-09-2023 6:53 PM
“ if the server light is still red, please unplug everything from the router and leave only the hub plugged in - if this still hasn't changed after 5 mins, get in touch with your ISP to ensure your firewall settings are set appropriately: Port 87 needs to be Open with Protocol UDP open within this port”
06-09-2023 7:10 PM
Total 'male cow excrement', I've never met an isp or router that blocks any outgoing traffic.
You might look at this thread and check that an nslookup will resolve the server name director.myenergi.online
06-09-2023 7:29 PM
06-09-2023 7:34 PM
Sorry, forgot to post the link https://myenergi.info/hub-not-connecting-to-the-server-t2950.html
06-09-2023 7:34 PM - edited 06-09-2023 7:36 PM
I can confirm connection should be possible.
Using a Windows power shell command Test-NetConnection
PS C:\> Test-NetConnection director.myenergi.online -Port 87
ComputerName : director.myenergi.online
RemoteAddress : 185.106.134.196
RemotePort : 87
InterfaceAlias : WiFi
SourceAddress : 192.168.10.100
TcpTestSucceeded : True
I am currently using a Hub two
HTH
Which Hub are you using?
06-09-2023 7:43 PM
Thanks @Dan_the_Van , that's what I would expect. I couldn't do that at the moment I'm posting from my tablet.
@MAXDRAXX have you tried the firmware update procedure https://support.myenergi.com/hc/en-gb/articles/360020110577-Updating-the-firmware-on-your-hub
06-09-2023 7:54 PM - edited 06-09-2023 7:56 PM
Think it worked I have also tested 185.106.134.196 UDP port 87 using https://www.ipvoid.com/udp-port-scan/
As a sanity check UDP port 80 showed as closed
06-09-2023 8:03 PM
06-09-2023 8:05 PM
06-09-2023 8:12 PM - edited 06-09-2023 8:13 PM
This https://www.plus.net/help/broadband/router-information/ will help identify what hub you have, but it doesn't really matter , none of the plusnet hubs will block port 87!
Do you have Internet access fro m other devices connected to the plusnet hub ?
Just a thought , you're not connecting the energyi hub to the red wan port on the plusnet hub are you ?
It needs to be connected to a yellow lan port
06-09-2023 8:15 PM
