Trying to connect MyEnergi Hub requiring port 87 to be open
MAXDRAXX
Hi folks. I’m trying to connect my MyEnergi Hub to broadband via Ethernet. I’ve been told by MyEnergi that port 87 needs to be open. I’ve looked through support and can’t see how to do this please help!
Tags (3)
15 REPLIES 15
Mustrum
Fixes: 81
Re: Trying to connect MyEnergi Hub requiring port 87 to be open
@MAXDRAXX   it says nothing about that in the instructions - https://www.myenergi.com/wiki/hub/hub_overview/
Have you updated to the latest firmware?
Fixes: 526
@MAXDRAXX it only needs to be open for outgoing connections. All ports are open for outgoing connections
MAXDRAXX
Hallo! No haven’t upgraded to latest firmware. I thought I’d need a working internet connection for that?
MAXDRAXX
Hi! I was just emailed this by MyEnergi support:
“ if the server light is still red, please unplug everything from the router and leave only the hub plugged in - if this still hasn't changed after 5 mins, get in touch with your ISP to ensure your firewall settings are set appropriately: Port 87 needs to be Open with Protocol UDP open within this port”
Fixes: 526
Total 'male cow excrement', I've never met an isp or router that blocks any outgoing traffic.
You might look at this thread and check that an nslookup will resolve the server name director.myenergi.online
MAXDRAXX
Sorry. I’m totally new to all this. Which thread? And is this something I resolve with the Hub or the Plusnet connection?
Fixes: 526
Sorry, forgot to post the link  https://myenergi.info/hub-not-connecting-to-the-server-t2950.html
Fixes: 124
@MisterW
I can confirm connection should be possible.
Using  a Windows  power shell command Test-NetConnection
PS C:\> Test-NetConnection director.myenergi.online -Port 87
ComputerName : director.myenergi.online
RemoteAddress : 185.106.134.196
RemotePort : 87
InterfaceAlias : WiFi
SourceAddress : 192.168.10.100
TcpTestSucceeded : True
I am currently using a Hub two
HTH
@MAXDRAXX
Which Hub are you using?
Fixes: 526
Thanks @Dan_the_Van  , that's what I would expect. I couldn't do that at the moment I'm posting from my tablet.
@MAXDRAXX have you tried the firmware update procedure https://support.myenergi.com/hc/en-gb/articles/360020110577-Updating-the-firmware-on-your-hub
Fixes: 124
@MisterW
Think it worked I have also tested 185.106.134.196 UDP port 87 using https://www.ipvoid.com/udp-port-scan/
As a sanity check UDP port 80 showed as closed
MAXDRAXX
I’m not entirely sure how to tell what model of hub it is. How would I find out please?
MAXDRAXX
I’ve tried following the instructions for a firmware update but if the server light is red, will it be able to proceed? I can’t tell if it’s updated or not.
Fixes: 526
This https://www.plus.net/help/broadband/router-information/ will help identify what hub you have, but it doesn't really matter , none of the plusnet hubs will block port 87!
Do you have Internet access fro m other devices connected to the plusnet hub ?
Just a thought , you're not connecting the energyi hub to the red wan port on the plusnet hub are you ?
It needs to be connected to a yellow lan port
MAXDRAXX
Thanks for that. It looks like I could try plugging the hub into a friend’s router and trying the updates?
