Troubles with passwords to Download emails to Thunderbird
- Troubles with passwords to Download emails to Thun...
11-08-2008 8:21 PM
Each request for a password to download mail in a Plusnet mailbox has been successful and the mail has indeed downloaded.
That is with the exception of one Thunderbird account and Plusnet mailbox. In that case even though I input the correct password it keeps getting rejected. I have even edited the Plusnet settings and overwritten the old password, albeit with the same one, in case that jogged the system, but the password is still failing.
I am completely stumped and would be glad of any helpful suggestion.
Re: Troubles with passwords to Download emails to Thunderbird
12-08-2008 9:03 AM
Tools -> Options -> Privacy -> Passwords -> Edit Saved Passwords -> Show Passwords
(at least that's the sequence of selections in Thunderbird 2.0.16).
If one is being a bit 'sticky' at changing, then maybe you could remove it from the list and try again?
12-08-2008 9:31 AM
In any case even if I did not ask for TB's password manager to remember it, I'd've thought it was PN that would have to validate the word. To me that points to something at the PN end. Of that I am even more convinced as not only did I make several attempts, even resetting the word in PN, but also re-entered the account in to TB after I wrote my OP with no different outcome.
BTW I can send from address with no trouble.
12-08-2008 2:27 PM
That would bypass any Thunderbird involvement?
12-08-2008 3:38 PM
12-08-2008 8:45 PM
[color=purple]What the dickens else can I do other than what I have both in TB and PN?
12-08-2008 9:37 PM
12-08-2008 10:47 PM
13-08-2008 7:48 AM
13-08-2008 7:54 AM
13-08-2008 9:33 AM
Quote from: pierre_pierre ...look at mails without opening them with thunderbird...
I referred to using Plusnet webmail here. Is that what you mean?
13-08-2008 9:43 AM
13-08-2008 9:54 AM
In Thunderbird, if you dodn't have the message pane visible, then the email message is not going to be displayed when you select it.
Then if you click on the email to select it and and choose the menu selection View - Message Source, you will see the raw email headers, including the "properties" and everything else.
13-08-2008 4:04 PM
