Trouble with mumble
- Trouble with mumble
Re: Trouble with mumble
14-02-2012 11:57 AM
reetpetite: Ok, so mumble isn't being identified correctly, BUT looking at your wireshark, there doesn't seem to be anything wrong with your download packets. Their RTT all looks fine and the queues that the mumble traffic is dropping into looks fine.
It sounds like something wrong with your upload datastream though. I'm checking a bit further.
Ex-Broadband Service Manager
14-02-2012 5:56 PM
14-02-2012 6:16 PM
Quote from: reetpetite Uptime: 0 days, 0:29:41
FEC Errors (Up/Down): 65,312 / 0
CRC Errors (Up/Down): 1,281 / 158
HEC Errors (Up/Down): 7 / 363
That's a lot of CRC errors on the upstream for an uptime of just under 30 minutes. Could that be the cause?
14-02-2012 6:37 PM
15-02-2012 9:34 AM
16-02-2012 9:28 AM
16-02-2012 7:34 PM
feedback imminent
16-02-2012 7:50 PM
It had been more or less fine for over a year until you got reset recently.
I am now getting interruptions in the downstream as well, so its incomprehensible and I am incomprehensible to others.
I am lagging so badly logging in takes 10 seconds and moving between channels (which is usually instant) takes 10 seconds or more.
The server seems to default to UDP and switch to TCP under duress.
Whatever you changed made it 10x worse alas.
New wireshark: http://www.mediafire.com/?yu51ukc2m77ds9w
Pingplotter attached too (lol)
BTW I totally appreciate your efforts.
You know how it is with Eve, if you aren't on coms you can't contribute.
Not wanting to be an arse about it, but this is pretty much the cornerstone of all my internet activity.
Any chance you could share some of the technical gubbins? I mean, QOS and packet management should comprehensivly tackle this issue right? You just need to get your filters to prioritize mumble etc?
But if it was as simple as setting up a definition, you'd have fixed it already .. so what gives? I'm genuinely interested hehe. I am guessing it is something to do with the relationship between plus and BT?
I was under the impression that plusnet is an ISP aimed at casual/low impact users so there shouldn't be a business reason why this is happening?
16-02-2012 8:08 PM
17-02-2012 9:29 AM
17-02-2012 11:39 AM
19-02-2012 12:05 AM
Quick log in and audio quality much improved.
It seems that mumble/ts works great with this 'pro' profile and not at all with whatever I was on before. Hehe.
So is this a case of you troubleshooting what causes the non pro-profile to make voip unusable, or am I going to be allowed to continue enjoying great coms?
19-02-2012 12:20 AM
26-02-2012 11:55 AM
27-02-2012 3:20 PM
Same issue as before (upstream not right?) Did it fix itself or stay bad all day? When did it go wrong?
I'm digging.
