Trouble setting up Asus RT-N66u router
shure
Tried to set up my shiny new RT-N66u last night but not having any joy.  I am on ADSL (ADSL1, no less) and most of the posts I've seen here are for fibre.
I have a Netgear DG834PN which I have set up as a modem only with the stock firmware.  I have not changed any other settings on this hardware.  I have tested the connection by connecting a cable to the PC and I can get internet.  So far so good.  I then disconnected this cable.
  I connected an ethernet cable from a LAN port on the Netgear to the RT-N66u on the WAN port. I have connected from the Asus LAN to the PC.  Initially I had severe issues just connecting to the Asus GUI but after a couple of modem reboots managed to do so.
Here's where it starts to fall apart.
I'm given choices for what sort of connection to use but can't seem to connect no mater what.  I initially tried Automatic IP (DHCP) but just got a timeout.  I then tried PPPoE and the same.  The steps are below (I borrowed pics from a previous post as they matched my issue, although the resolution didn't work for me).
PPPoE
Input my user name and password provided by my ISP
The brick wall  Huh
I'm sure I'm missing something simple but haven't got a clue what..  Can anybody help?
19 REPLIES 19
2Senile
Re: Trouble setting up Asus RT-N66u router
ADSL setting is PPPoA.
Is there another way to set up your Router manually?
shure
I suspected that might be an issue but the options in the first pic are the only ones the router will give me.
HaresEar
am not sure but this could be a FTTC only router. Try ring or as I did e-mailing Asus help.
I had a N55U which is an ADSL router and connected manually no problems.  However my wi-fi does not work.
shure
I've seen other people use it on ADSL.  Think there just must be something wrong with my settings
bill888
Champion
Fixes: 38
fwiw, I would suggest you double check your Netgear router is correctly configured and working in bridged mode.
If you have a Windows PC, here are Vista & Win7 instructions for hooking up PC direct to your Netgear to test PPPoE.
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
PPPoE does work on ADSL.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
2Senile
http://www.asus.com/Networking/RTN66U/HelpDesk_Manual/
According to the Manual
• The auto-detection of your ISP connection type takes place
when you configure the wireless router for the first time or
when your wireless router is reset to its default settings.
Worth a try?
shure
Hmm, I've managed to set it up but with the Netgear back in router mode.  Everything else has remained the same.  So basically I have two routers connected: shouldn't that cause conflicts?
Setup:
Internet (ADSL) > Netgear DG834PN > LAN > ASUS RT-N66u (WAN)
Is there a reason why it should work with the Netgear set up as a router but not when it's set up as a modem only?
BTW I used the first connection option: Automatic IP (DHCP).
Will this cause problems and should I change something?
shure
OK.  When I change my Netgear to modem only mode, all my clients still say they are connected to the internet but I can't actually open a web page or do any other online activity.  This happens on both wireless and LAN.  When I set the Netgear back to modem+router mode everything works fine.
On the face of it, it would seem OK to just leave things as they are but I want to make sure that I'm not causing potential future problems by doing things this way.  I've disabled wireless on the Netgear but that's about it.
Can somebody knowledgeable on these things please advise?
2Senile
Check DNS settings in the Asus?
shure
Thanks, but what am I looking for?
dick:quote
2Senile
You are probably alright on the DNS settings but it could be worthwhile checking the settings haven't been corrupted:
Begin on the Status page of the Asus RT-N66U. To change the Domain Name System settings, click the choice on the left side of the page labeled LAN, which is located underneath Advanced Settings.
On this new page, click the tab at the top of the page labeled DHCP Server.
"Configure the DNS section of your Asus RT-N66U"
Scroll down until you come to the section labeled DNS and WINS Server Setting.
In the box specified DNS Server there should be an address such as 208.67.222.222 or 8.8.8.8. If there is something similar you should be fine. if it is blank just enter either of the addresses.  Click the Apply button at the bottom of the page.
Some devices on your network may not begin using the new DNS settings until they have been rebooted. After rebooting a device you can go to its network settings and verify that it is using the DNS servers that you specified.
shure
I'll do that, thanks.  But if it's blank and working what are the advantages of filling it in?
bill888
Champion
Fixes: 38
If you use Netgear in router mode, and Auto IP is set up on Asus, it means you have a double NAT configuration.  Usually not recommended, but it does work fine for most users.
If you later need to open up tcpip ports for whatever reason, you may discover you have made it more difficult for yourself to set up.  You could put the Asus into the DMZ mode of your Netgear router to partially alleviate this issue.
An alternative is to set up the Asus as a wireless access point only and rely on the Netgear to do all the routing.
Just a thought, when you set up the netgear in bridge modem mode, did you use the correct values for the ADSL settings for VPI, VCI and Encapsulation ?
ie. 0, 38 and LLC-based respectively  usually for most modems. (Do not use VC-mux)
shure
I assigned the Asus to the DMZ of the Netgear for the moment and I have disabled the wireless on the Netgear too.
I only want to use the Netgear as a modem and have the routing (and basically everything else) done by the Asus.
I did try to change the Multiplexing Method to LLC when I originally put the Netgear in modem only mode but this resulted in me being unable to establish a connection, so I reverted to VC.  The other values are 0 and 38.
On the Netgear, I have:
- Disabled port Scan and DOS Protection (unsure if that's necessary if the Asus is in DMZ)
- Put the Asus in the DMZ
- Disabled wireless
-VPI 0
-VCI 38
-VC Based
-Using Router as DHCP Server
The Netgear IP range runs from 192.168.0.1 to 192.168.0.254 while the Asus runs from 192.168.1.1 to 192.168.1.254.  I assumed there would be no conflict as a result
Should I change any of the above and / or other settings?
I have left the Asus to its default settings for now
