Tried to raise a speeding ticket - but it failed
- Tried to raise a speeding ticket - but it failed
18-03-2011 7:55 PM
I tried to complain that my 5Mbps sync rate is very sluggish by attaching an image file.
I explained the situation, attached my attachment.
PN then blanked my text on the spurious grounds that my file was too "long".
Notice that download speed = upload speed.
[edit] It works here!!!!!!! [\edit]
Message 1 of 4
(665 Views)
3 REPLIES 3
Re: Tried to raise a speeding ticket - but it failed
21-03-2011 9:35 AM
Hi Axofilevus,
It's not attached to the ticket because there's a space in the filename - if you remove that it should attach fine.
Hope that helps,
Hope that helps,
Message 2 of 4
(371 Views)
21-03-2011 12:11 PM
Thanks - I'll rename attachments in future.
AFAIK a space is a valid character in all present day file systems?
Message 3 of 4
(371 Views)
21-03-2011 1:33 PM
Hi Levixofas,
Indeed, though our ticket system is not really a file system per se. It's an annoying workaround to be sure but it's better than not being able to upload attachments at all.
Message 4 of 4
(371 Views)
