Translation of BT Speedtester result.
- Translation of BT Speedtester result.
24-07-2010 6:19 PM
Could someone in the know please elaborate on the attached pic? I fully understand it except for the three lines starting "The throughput of Best Efforts classes...etc " to "... the way your ISP has decided to use these traffic classes". In particular, what do the numbers 17.02:25.29:57.69 refer to?
Thanks in anticipation.
Message 1 of 3
(792 Views)
2 REPLIES 2
Re: Translation of BT Speedtester result.
26-07-2010 11:21 AM
I don't know about the numbers you mentioned, the important bits are...
DSL connection rate = sync speed
IP profile = IP profile
Download speed = throughput
Message 2 of 3
(385 Views)
26-07-2010 12:53 PM
from the BT Speed test handbook
Message 3 of 3
(385 Views)
