Transferring to Plusnet
- Re: Transferring to Plusnet
18-11-2013 1:57 PM
Hi all,
I hope someone can help. We're in the process of transferring our fibre broadband service to plusnet. We are currently with BT and have their Homehub 4 router.
I'm a little nervous, having read reviews, about using the supplied plusnet router, by all accounts the strength of signal etc is not as good as the HH4.
I understand it is possible to use the HH4 with the new plusnet service. However, having searched the site and google I'm struggling to understand exactly what I need to do.
I would be very grateful if someone could explain (in such a way that an idiot would understand) how I go about completing this.
Do I need to connect the Plusnet router up first once the transfer date arrives, or can I simply alter settings on my HH4 to use the plusnet service? Transfer dates is imminent so I want to be able to get this working from the beginning if possible (it's taken plusnet 8 weeks so far to get us transferred, I'm hoping the service once we're connected begins to improve as I haven't been impressed so far!)
Any help gratefully received.
Regards
Regards
Message 1 of 5
(742 Views)
4 REPLIES 4
18-11-2013 2:17 PM
Apologies,
I think this link http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/ answers my question. You always find what you're looking for once you've asked the question!
Sorry
My only other questions are whether this can be done as soon as the plusnet service is active, or does the plusnet router need to be connected first? and will the WiFi name etc remain the same for the hub or will I need to reconfigure everything which has wireless connection to it?
Sorry
Message 2 of 5
(453 Views)
18-11-2013 2:20 PM
You don't need to connect the Plusnet router first, your wi-fi name/password will stay 'as-is'.
Call me 'w23'
Message 3 of 5
(453 Views)
18-11-2013 5:03 PM
i use the home hub 4 and it does work with plusnet
Message 4 of 5
(453 Views)
18-11-2013 5:09 PM
http://192.168.1.254/ then go to Settings use the admin password that comes with the router then you put in your Broadband username and password and press connect thats how you connect a home hub 4 to plusnet
Message 5 of 5
(453 Views)
