Transfer to 21C Network/REIN Problem [RESOLVED]
- Transfer to 21C Network/REIN Problem [RESOLVED]
Re: Transfer to 21C Network
23-06-2013 10:30 PM
23-06-2013 11:03 PM
23-06-2013 11:12 PM
23-06-2013 11:18 PM
24-06-2013 10:01 AM
24-06-2013 7:07 PM
25-06-2013 12:50 AM
FEC Errors (Up/Down): 0 / 107,458,386
CRC Errors (Up/Down): 85,650 / 815,185
HEC Errors (Up/Down): 28,788 / 681,276
[Edit]
15 minutes later
FEC Errors (Up/Down): 0 / 116,707,154
CRC Errors (Up/Down): 93,069 / 886,262
HEC Errors (Up/Down): 31,249 / 735,755
25-06-2013 8:51 AM
25-06-2013 11:44 AM
I've powered down the router and reconnected this morning, these are the error stats for 30 minutes uptime
Error Seconds (Local/Remote): 1,735 / 1
FEC Errors (Up/Down): 0 / 14,405,061
CRC Errors (Up/Down): 15,981 / 110,972
HEC Errors (Up/Down): 5,523 / 161,962
25-06-2013 12:56 PM
Quote from: gtowen both CRC and FEC errors are flat-lined at the top of the graph
This implies that your values are greater than the current Y Axis clipping level. The default options are to have clipping enabled and a relatively low clipping level.
Have you tried unchecking the "Enable Clipping" or checking the "Logarithmic Y Axis" options
25-06-2013 1:05 PM
I've just disabled clipping to see how high the figures are and included the graphs
25-06-2013 7:02 PM
27-06-2013 2:27 PM
[Edit] Just noticed something weird, previously whenever the interference appeared, the FEC and CRC errors would go through the roof. At the same time SNRM would dip sometimes from 12 to as low as 10.5. At the moment the SNRM is steady at about 12.1
01-07-2013 12:26 PM
01-07-2013 12:35 PM
Without seeing the precise wording on the last ticket response, if it's more or less as you say, I think I'd put a reply on the ticket something along the lines of the following -
Quote I don't think you fully understand what is going on here. I have already provided some evidence and detail of the Interference that is periodically happening to my line ie REIN, albeit a slight misuse of the term as it isn't strictly Impulse, but it's the term everybody uses for Interference.
As it's not present all the time, then of course if you test the line when there is No Interference active then you will not find a particular problem. But as it would appear from one of your previous responses, that you don't seem to have even checked the recent Line and DLM history, I'm not surprised that you continue to claim there is nothing wrong.
If you investigated properly you would be aware of all the disconnects that I'd been suffering similar to those shown on a vis radius posted by Chris Purvey in one of my forum threads, and the fact tha my Target SNRM went from 6dB to 12dB in a matter of days.
As you can see from recent Modem/Router stats attached, it doesn't take a genius with a calculator to see the huge error rate when the interference is present. This makes the connection virtually unusable.
Please pass this ticket to someone who knows how to investigate these issues properly.
In addition to the basic facts, as I'm not a telephone engineer, it's only as a result of my current forum thread that I've discovered the Openreach did a substandard job of reconnection this line 2 years ago and there are issue with the external cable and some internal cable they installed which is not to the correct CW1308 standard and will be contributing to these problem. This matter needs to be taken up with Openreach.
I'd attach/insert the stats from reply #96 also, even if you have done before.
Edit: And those from reply #98 as well
