Transfer to 21C Network/REIN Problem [RESOLVED]
- Transfer to 21C Network/REIN Problem [RESOLVED]
Re: Transfer to 21C Network
21-06-2013 8:35 PM
Quote We have tested your line and have been unable to identify issues outside of normal parameters on the line.
I do note that your records are showing some errors on the line, but as these are not exhibiting on the exchange equipment. This makes me believe that the errors on your logs are showing error rates pre-correction. If these minor errors seen are able to be corrected by the equipment, then they will not be having any effect on your service.
I note that you are asking for a REIN engineer to investigate further, however we need for the line to be exhibiting line errors and/or significant drops on the line for our suppliers to be able to investigate, and we are seeing "green" parameters on your line across the board.
I'm not surprised their equipment isn't showing anything, my SNRM is set high to suppress these errors and interleaving is on. As to these errors not affecting my service, I'd consider a 20-25% reduction in speed a considerable effect.
I'm really annoyed that a REIN engineer will not be called out. At the moment PN are quite happy to give me sub standard service while allowing the law to be broken.
21-06-2013 9:24 PM
21-06-2013 9:50 PM
Current stats:
You are currently connected to gateway ptw-ag04.
This is located in Telehouse West.
Phone exchange:
HOLYHEAD
Estimated line speed:
8Mb (This may vary between 6Mb and 10Mb) - Checked on 2013-04-23 02:54:03
Current line speed:
10.5 Mb
Download speedachieved during the test was - 9.98 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.2 Mbps
Upload speed achieved during the test was - 0.63Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
DSL Connection
Link Information
Uptime: 0 days, 5:17:46
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 11,563
Data Transferred (Sent/Received) [GB/GB]: 4.60 / 4.93
Output Power (Up/Down) [dBm]: 11.8 / 0.0
Line Attenuation (Up/Down) [dB]: 14.3 / 27.5
SN Margin (Up/Down) [dB]: 14.4 / 12.0
Loss of Framing (Local/Remote): 18 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 40 / 0
FEC Errors (Up/Down): 13 / 157,375
CRC Errors (Up/Down): 0 / 24
HEC Errors (Up/Down): 0 / 45
21-06-2013 10:58 PM
Which Filtered Faceplate did you get in the end?
Have the fans been running during those 5 hours of uptime on the stats?
21-06-2013 11:16 PM
http://www.amazon.co.uk/gp/product/B003H6GUNA/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
The fans have been running since 11:00hrs this morning and have only just stopped.
Average error rates over a 24 hour period
24 hours starting 21 Jun 2013 10:51:10
Per second Per minute Per hour Per day
CRC Up 0 0 0 0
Down 0 0.04 2.34 56.2
FEC Up 0 0.02 1.05 25.2
Down 8.79 527 31637 759277
HEC Up 0 0 0 0
Down 0 0 0 0
ES Up 0 0 0 0
Down 0 0.05 2.90 69.7
22-06-2013 11:47 AM
http://www.expect.openreach.co.uk/people-at-home-work/electrical-noise-effects-on-broadband-services...
22-06-2013 12:00 PM
Quote Unfortunately there is no current legislation that allows us or the telecommunications regulator (OFCOM) to take action against such faulty equipment.
and yet on this link :http://www.conformance.co.uk/adirectives/doku.php?id=emc
Quote In the UK the Directive is enforced by the Trading Standards Service and Ofcom. Penalties for non-compliance can include three months imprisonment and a £5000 fine but generally involves a recall and replacement of the affected product.
So how can they claim there's no legislation when a £5000 fine or 3 months imprisonment seems like an enforceable legislation to me
22-06-2013 12:27 PM
22-06-2013 12:35 PM
@gtowen
When the fans aren't running (ie when your SNRM in not being reduced by the Interference) during the day, can you do a PPP Disconnect and power down for 10 minutes. Power up and don't forget to login and click Connect.
This will give us a completely clean slate of stats so we can see exactly what beneficial effects the filtered plate is having - limited evidence from the modem/router so far suggests it's helping rather. I wouldn't place too much significance on those average stats you posted for the time being, as I indicated previously the figures can vary somewhat, depending on how and when certain errors occurred and I've also found the figures don't always seem to relate directly to the actual errors.
22-06-2013 1:15 PM
You are currently connected to gateway ptw-ag03.
Phone exchange:
HOLYHEAD
Current line speed:
10.5 Mb
Download speedachieved during the test was - 9.99 Mbps
Upload speed achieved during the test was - 0.67Mbps
DSL Connection
Link Information
Uptime: 0 days, 20:38:13
Data Transferred (Sent/Received) [GB/GB]: 7.24 / 12.35
SN Margin (Up/Down) [dB]: 14.4 / 13.8
Error Seconds (Local/Remote): 43 / 0
FEC Errors (Up/Down): 13 / 909,311
CRC Errors (Up/Down): 0 / 30
HEC Errors (Up/Down): 0 / 52
With just the one fan running, maybe I've narrowed the problem even further, but only a REIN engineer can prove it.
I'm also wondering if I should request an SRNM reset, at the moment its fixed at 12db
22-06-2013 2:21 PM
However, just dropping the PPP sessions doesn't reset any of the stats figures. The point of dropping PPP first, is that with no active session when you power off the modem/router, DLM sees it as user action, not a random drop of sync. I would not recommend doing it whilst any fans are running, if there is noise being generated and picked up at present, it will result in reduced achievable sync speed (nor anywhere near dawn or dusk or after dark - noise levels will be higher).
An SNRM reset is something to go for WHEN you are sure you have more stable conditions which you certainly can't be at present. You can't get a fault raised to BTw whilst a line is in training, this will limit your options, especially if things got worse.
22-06-2013 2:29 PM
22-06-2013 3:02 PM
23-06-2013 10:37 AM
This morning I disconnected the PPP @ 09:45 hrs. Switched off the router @ 10:00hrs and then went out for the sunday papers. Switched the router back on 10:25hrs and took these stats ;
You are currently connected to gateway ptw-ag02.
Phone exchange:
HOLYHEAD
Current line speed:
10.5 Mb
Download speedachieved during the test was - 10 Mbps
IP Profile for your line is - 11.39 Mbps
Upload speed achieved during the test was - 0.68Mbps
DSL Connection
Link Information
Uptime: 0 days, 0:03:46
Bandwidth (Up/Down) [kbps/kbps]: 888 / 12,914
Data Transferred (Sent/Received) [kB/kB]: 127.35 / 462.24
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 14.3 / 27.0
SN Margin (Up/Down) [dB]: 14.1 / 12.1
FEC Errors (Up/Down): 0 / 6
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
From these stats you can see SNRM has dropped back to 12db, my sync speed has gone up to just under 13Mb/s and my BTw ip profile has gone up to 11.39 Mb/s.
So got no idea what is going on :(. Maybe if I'm lucky the mysterious noise offender has blown itself up and won't cause anymore problems....... shouldn't have watched the new Oz film last night.... no ruby slippers here.
23-06-2013 6:02 PM
