Training, use plusnet router?
- Training, use plusnet router?
02-11-2013 9:15 AM
Our line recently went active and rather than using the plusnet supplied router/modem I'm using a new Draytek Vigor 120 modem and my cable router. I'm just wondering if for the training period I should be using the plusnet modem or does it really not matter?
The draytek is reporting we're on G.DMT and syncing around 6/0.4 megabit up/down with an SNR around 6/7 and att around 42. Should this be switching to G.992.3 or G.992.5 at some point? Its been on all night and stable.
Thanks,
Ste
Re: Training, use plusnet router?
02-11-2013 10:24 AM
Regarding changing from G.DMT the first question is whether your exchange is 21CN enabled - check here http://usertools.plus.net/exchanges/
If it is then I should try setting the modem to auto rather than specifying it
02-11-2013 10:31 AM
The modem is set to mixed modulation rather than specifying one. I assume this means its set by the line?
Code: WNOAK
County: Shropshire
Enabled: 03 Mar 2004
Market: 3
Mkt2014: B
Colour: Green 20CN VP capacity at this exchange is currently showing as Green.
Click here for further details
Colour: Green BT have advised that this exchange is enabled for WBC on 21CN
Colour: Unknown You can view recent Service Outages for this exchange here
Colour: Unknown BT have published Max DSL upgrade information for this exchange
The following services are available in your location:
BT Wholesale ADSL
BT Wholesale ADSL Max
BT Wholesale WBC (21CN)
TalkTalk (CPW) LLU
Sky Broadband / Easynet LLU
Virgin Media (Cable)
02-11-2013 10:43 AM
02-11-2013 10:53 AM
02-11-2013 11:04 AM
As a check can you run the BT speedtest further diagnostics http://speedtest.btwholesale.com/
You should see something like this
02-11-2013 11:30 AM
02-11-2013 11:40 AM
Going to ADSL2 should give you higher speeds
I suggest leaving things alone until Monday when the staff on here should be able to check
02-11-2013 12:10 PM
04-11-2013 10:26 AM
Jim's got it spot on, I've just placed an order to move you onto ADSL2+ with uncapped upstream which should complete tomorrow. Not sure what the speed increase will be like but hopefully you'll see some
04-11-2013 10:28 AM
Will report back if I see any change in the next couple of days
04-11-2013 10:42 AM
04-11-2013 1:08 PM
04-11-2013 1:15 PM
Just to check in terms of training, is syncing the only thing that matters? As I'm currently using a separate modem and using my cable router to connect via PPPOE I'm wondering if rebooting the router but leaving the modem synced would make it think it was a disconnect and the line was unstable?
04-11-2013 1:40 PM
The training period will recalculate your Fault Threshold Rate and Maximum Stable Rate so it's important we keep a stable connection throughput the training period.
