Training Period
AMX
Training Period
  Just changed from Value to Unlimited having been offered a good deal and told my line speeds would be improved. My 10 day training period has now ended and my line is now at least 1/2 meg slower . Can someone from Plusnet please give it a kick .
                    regards,
                          AMX
DSL Details
Modem Type: Built in modem - ADSL
DSL Line (Wire Pair): Line 1 (inner pair)
Current DSL Connection:
Down Up
Rate: 2464 kbs 445 kbs
Max Rate: 2297 kbs 804 kbs
Noise Margin: 8.3 dB 17.2 dB
Attenuation: 63.0 dB 33.5 dB
Output Power: 17.2 dBm 12.4 dBm
Protocol: G.DMT2 Annex A
Channel: Interleaved
DSLAM Vendor Information Country: {46336} Vendor: {IFTN} Specific: {51313 }
ATM PVC: 0/38
Rate Cap: 2297 kbs
Attenuation @ 300kHz: 63.0 dB
Uncanceled Echo: -23.1 dB Ok
VCXO Frequency Offset: -1.6 ppm Ok
Final Receive Gain: 34.5 dB Ok
Excessive Impulse Noise: 1 More Impulse Noise Protection Recommended
Traffic Statistics
IP Traffic Bytes Packets Errors %
Transmit: 108181375 97 0 0
Receive: 3708159799 3292307 0 0
ATM Traffic Cells Errors %
Transmit: 5651093 0 0
Receive: 79606272 0 0
DSL Link Errors
Collected for 6Days9:26:40
Since Current Current Time Since
Reset 24-hr int. 15-min int. Last Event
ATM
Last Event
Cell Header Errors 102681 2790 17 0:00:22
Loss of cell Delineation 19821 229 1 0:01:37
DSL
Link Retrains: 0 0 0 0:00:00
DSL Training Errors: 1 0 0 6Days9:25:02
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 3 1 0 2:51:33
Loss of Signal Failures: 0 0 0 0:00:00
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 0 0 0 0:00:00
Cum. Seconds w/Errors: 30470 1907 15 0:00:19
Cum. Sec. w/Severe Errors: 431 1 0 2:51:33
Corrected Blocks: 1445583 73655 736 0:00:02
Uncorrectable Blocks: 116931 3270 22 0:00:19
DSL Unavailable Seconds: 115 0 0 6Days9:24:44
1 REPLY
Fixes: 49
Re: Training Period
Whoever told you that is being 'a bit economical with the truth'. Changing product won't affect the line speed and doesn't cause a new 'training period'.
Judging by the stats you have a pretty long line and are not likely to get VERY much better speeds. Your noise margin is a tad high though, although that may be because the last resynch was at a 'bad' time of day and the margin has improved since then. You MIGHT get better results from an ADSL1 connection, with that line length, but your router(a 2700HGV aka Business hub from the stats) won't allow you to force ADSL1. It would need PN to reset to an ADSL1 connection.
