Traffic Prioritisation Ports
- Traffic Prioritisation Ports
03-02-2013 10:59 PM
On the https://portal.plus.net/support/broadband/speed_guide/traffic_management.shtml page it says that plusnet won't correct identify traffic using non-standard ports. However it doesn't actually specify which ports map to which plusnet categories, which isn't terribly helpful. Is there a more useful breakdown somewhere?
I'm asking because I'm seeing performance issues with VPN. I suspect it's a traffic management issue, but without knowing the exact port mappings I can't confirm this.
Message 1 of 3
(737 Views)
2 REPLIES 2
Re: Traffic Prioritisation Ports
03-02-2013 11:02 PM
you can try a wireshark capture and that will give you your downstream priority.
Message 2 of 3
(364 Views)
04-02-2013 1:23 AM
That page doesn't say traffic from applications using non-standard ports *will not* be correctly classified, just that it *can* happen. Wireshark enables you to check.
If you are unfamiliar with Wireshark and traffic prioritisation marking see article Using Wireshark for Data Capture.
David
Message 3 of 3
(364 Views)
