Traffic Management system (64987)- UPDATE
- Traffic Management system (64987)- UPDATE
Re: Traffic Management system (64987)- UPDATE
20-12-2010 2:46 PM
20-12-2010 2:48 PM
Quote from: puddy
so its not traffic management probelm if I can download at this speed or is it?
Puddy - the broadband speed test runs over http and isn't a download from a download site. The default profile, I suspect, has not rate limitations on http but throttles others greatly such as ftp / p2p/ newsgroups etc
20-12-2010 2:52 PM
Are plusnet saying everybodY stuck at peak time speeds?
My account does not have any traffic shaping i am off peak 12am to 4pm and not gone over its limit or waiting for a bill to be paid
Yet my download speed shows
Can jojo clarify it for all us please?
Why my download speed so healthy if the service is on a go slow and sync still at 8128
Puddy
(jillweekes account)
sorry for the ping pong ball message adiewoo
did not mean to be rude you just beat me to it sorry
20-12-2010 2:54 PM
20-12-2010 2:54 PM
I do not understand why I should be affected by the traffic management issue as my account is PAYG with no restrictions.
Can anyone enlighten me please ?
Mike (edgeways
20-12-2010 2:56 PM
20-12-2010 2:59 PM
Quote from: Joanne the service status says, "Our traffic management platforms are 'frozen' at 9.00pm last night. Any traffic management restrictions that were applied to your account at this time of the evening will still be in place now.
so even though you are currently during your off peak time your restrictions that were in place at 9pm last night will still apply.
Jojo
20-12-2010 2:59 PM
seems everything effected
Puddy
thanks for the reply jojo
20-12-2010 3:00 PM
Quote View My Usage / Traffic Management system (64987)- UPDATE
Broadband
Posted on: Monday 20 December 2010, 11:23
This is an update to this morning's post about the problems we've been experiencing with our traffic management platform.
At approximately 9pm last night one of our databases suffered a disk failure which has caused a number of problems that may be affecting customers.
* Broadband usage for the last 12 hours or so may not be showing when checking the usage reporting tool available on our website.
* Our traffic management platforms are 'frozen' at 9.00pm last night. Any traffic management restrictions that were applied to your account at this time of the evening will still be in place now.
* If you've disconnected/reconnected between 9.00pm last night and now then you will have been assigned a 'default traffic management profile' from 9.00pm last night. This profile heavily restricts time sensitive activities such as Peer-to-Peer filesharing and Binary Usenet. It may also affect the use of some high-definition streaming services and download sites/servers.
* If your traffic is restricted due to exceeding your monthly allowance, and you are due to be billed today, then the restrictions are unlikely to be removed until the underlying cause of the problem is resolved.
* If your account has entered failed billing then you may be having difficulty making a payment and lifting the billing restrictions.
Only if you're in failed billing should you try disconnecting and reconnecting if you're having difficulty getting online after making a late payment.
In all other circumstances we recommend that you *avoid disconnecting/reconnecting* as you're likely to make the situation worse if you do.
We would like to apologise for the inconvenience and will post another update this afternoon.
Kind regards,
Customer Support
Return to Index
20-12-2010 3:01 PM
Quote from: adiewoo It's affecting everyone, not just you. Please read the status update.
The status update says
If your traffic is restricted due to exceeding your monthly allowance, and you are due to be billed today, then the restrictions are unlikely to be removed until the underlying cause of the problem is resolved."
That doesn't affect everyone. I appreciate hardware faults are beyond plusnets control but according to the service status not everyone should be affected.
Unless the problem is bigger than plusnet are admitting in which case honesty would be appreciated and a greater understanding from paying customers might be more forthcoming
20-12-2010 3:05 PM
Quote "Our traffic management platforms are 'frozen' at 9.00pm last night. Any traffic management restrictions that were applied to your account at this time of the evening will still be in place now.
As every account has a traffic management profile of some description, just that Pro / PAYG profile is full throttle 24/7. Unless those users have disconnected / connected since 9PM last night.
20-12-2010 3:05 PM
Quote from: edgeways I do not understand why I should be affected by the traffic management issue as my account is PAYG with no restrictions.
[quote=service status]* If you've disconnected/reconnected between 9.00pm last night and now then you will have been assigned a 'default traffic management profile' from 9.00pm last night. This profile heavily restricts time sensitive activities such as Peer-to-Peer filesharing and Binary Usenet. It may also affect the use of some high-definition streaming services and download sites/servers.
Jojo
20-12-2010 3:07 PM
Quote from: puddy I am only trying to view normal web pages and have never used p2p and am not downloading any files yet its still slow going
Puddy
Hi Puddy, I refer you again to the post I made earlier
Jojo
20-12-2010 3:12 PM
20-12-2010 3:16 PM
