Traffic Management: Usage penalty
Today I got my 13gb email warning
"Light restrictions will now apply to your connection speeds until the end of the current billing month."
The effect of these restrictions can be seen in the speed test results below
We are unable to use the internet satisfactorily this evening. Time to move on I think.
Edit: changed incorrect speed result
Fixes: 247
Re: Traffic Management: Usage penalty
Santiago, you've posted the same speedtest result twice?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
geewizz
If you get 5.2Mbps while being penalised then you're getting better value for money than I do. The maximum I get at ANY time of the month is 1.7Mbps.
Sorry chaps I have put the right one in now Embarrassed
Fixes: 247
I think you are been throttled at a lower rate than you should be, according to this it should be 2meg http://www.plus.net/support/broadband/products/archive/bb_premier1.shtml and you are getting 1.
There was another thread on this somewhere, might be worth raising a ticket.
geewizz
I would be delighted if i could get that as a steady speed. welcome to my world, even if it's just for a short visit. Remember, you have the luxury of being able to upgrade to get a higher usage allowance and regain your previous speeds.
@adiewoo
I thought there was thread on this in he recent past, couldn't find it.
@geewizz
always happy to visit with you.
Fixes: 247
Here it is http://community.plus.net/forum/index.php/topic,73396.0.html
I hadn't seen that one. I recall an earlier one on the same subject. I'll have look for it tomorrow.
It appears this is not a new problem
Back to normal this morning
James
Quote from: Santiago
Yes, it should be as those restrictions only apply to peak hours.
It's basically down to two things.  We apply a 1Mbps restriction on Mondays whilst we're under a network capacity situation of Amber.  I belive that it reverts to 2Mbps from Wednesday to Sunday, when we have slightly lower lovels of traffic.
In the level 1 management info it says up to 2Mbps.
I don't think it's right that at 66% of my monthly usage allowance I get pegged back to 1Mbps
James
It's been like that for literally years.
Looking at your usage Santiago, you'd almost definitely be better off using Option 3 as those sort of restrictions don't apply and I'd expect you to remain within your usage allowance.
geewizz
Does that not make the effective usage allowances 13GB and 20GB for options 2 & 3 respectively. This would make the advertised headline allowances of 20 & 300GB on  "up to 8Mb" a bit misleading (not for me obviously because I never reach the heady speeds of even the penalised speeds.)
Fixes: 10
James, Would he still be within the usage levels for option 3 with his off-peak 8am to 4pm added to his current peak usage?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
