Traffic Management? - Update
- Traffic Management? - Update
02-11-2011 9:18 AM
I'm also curious as to why the latency/ping times have increased since the change over to WBC and IPSC for my maaf connection, would it be correct to assume that the routing has changed for the worse, hence the increase in ping times and can PN do anything to improve things?
Re: Traffic Management?
02-11-2011 2:48 PM
your traffic management profile is as it should be. I doubt that the change to IPSC would affect the routing negatively.
Jojo
02-11-2011 2:52 PM
i'm on fibre.... i like to play COD - MW2 on PC (runs p2p protocol)
along with Left for Dead 2 on PC.....
MW2 connects me with europeon and further hosts......
Left for Dead tends to put me with French players.......
Although i moaned about o2 being rubbish (which they are), there routing made me connect with mainly UK players. fear not, i know theres nothing u can do, so i just have to settle for it...
02-11-2011 2:56 PM
Quote MW2 connects me with europeon and further hosts...
This is a known issue with MW2 and that's why they've said they are going to fix this style of matchmaking for MW3.
L4D - I used to play this and L4D2 and never had a problem being connected with non-uk players. (I'm on a Fibre connection too). You haven't got your Steam setting for location to somewhere in Europe have you.
02-11-2011 4:44 PM
Quote from: Joanne Hi Apprentice,
Jojo
OK Jojo and thanks for checking that out.
Any idea what could be causing the increased latency/ping times as all the gateways or whatever they are called now I've connected to over the last few weeks give similar ping times, which at least shows they are well balanced.
I'll investigate further regarding latency, WBC and IPSC but it looks like its not going to improve, maybe best to blame it on the advent of FTTC.
02-11-2011 4:58 PM
03-11-2011 9:29 AM
03-11-2011 11:31 AM
03-11-2011 3:06 PM
Re: Traffic Management? - Update
14-11-2011 1:55 PM
this coincided with the recent increase in bandwidth / lit segments for the 21CN PN customers, strange or not?
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=47ms TTL=249
Reply from 212.58.241.131: bytes=32 time=46ms TTL=249
Ping statistics for 212.58.241.131:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 46ms, Maximum = 47ms, Average = 46ms
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 48 ms 48 ms 48 ms lo0-central6.pcl-ag01.plus.net [195.166.130.87]
3 49 ms 47 ms 48 ms gi7-1-162.pcl-gw02.plus.net [84.93.255.83]
4 48 ms 47 ms 47 ms po5.thn-gw02.plus.net [212.159.1.133]
5 47 ms 47 ms 47 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 48 ms 47 ms 48 ms 212.58.238.149
7 47 ms 46 ms 47 ms virtual-vip-231.thdo.bbc.co.uk [212.58.241.131]
Trace complete.
14-11-2011 3:11 PM
Quote this coincided with the recent increase in bandwidth / lit segments for the 21CN PN customers, strange or not?
I would say more or less coincidental, than anything else... Still, good to see the issue resolving itself
Regards
