Too slow for Lovefilm now
- Too slow for Lovefilm now
13-02-2014 5:38 PM
I have only recently moved to Plusnet from Talk Talk. I get almost exactly, but just under, 2Mb download all the time. This is too slow for Lovefilm which needs 2Mb or it refuses access. I used to get this with Talk Talk but they changed some SNR or something setting and I jumped up to almost 4Mb. Do you have any similar thing you can do to increase my speed. I only need a fraction rise.
My modem is plugged straight into the master socket. Speedtest shows 1.99Mb
Message 1 of 9
(1,467 Views)
8 REPLIES 8
Re: Too slow for Lovefilm now
14-02-2014 9:18 AM
Hi Sacha,
Having looked at the results of a couple of diagnostic tests it looks like a change to the SNR (signal to noise ratio) may be possible. Where as that may increase the download speed you'd be able to achieve there is a risk that it might cause some disconnection issues.
If you're willing to give it a try let me know.
Adam
EDIT: As this is a reversible change I'll give it a go for you, after all you've done this with Talk Talk already.
You should hopefully notice some difference within the next couple of hours.
Adam
Message 2 of 9
(705 Views)
15-02-2014 4:51 AM
My first speed test shows that the speed has DROPPED to 1.77M.
Will try again later.
Message 3 of 9
(705 Views)
16-02-2014 11:14 AM
Speed tests now showing 2.5 MBS. That's plenty for me. Thanks a lot
Message 4 of 9
(705 Views)
17-02-2014 10:58 AM
Message 5 of 9
(705 Views)
17-02-2014 11:05 AM
@ Sacha - Have you looked at whether you can get fibre?
Message 6 of 9
(705 Views)
17-02-2014 11:51 AM
Unfortunately fibre not available in my area yet. Coming soon though I believe
Message 7 of 9
(705 Views)
19-02-2014 8:12 AM
Looks like I was a bit premature. The speed has DROPPED to 1.77Mb. This speed is consistent at peak time and middle of the night and it seems to be always 1.77Mb as if its a cap. Can you please check to make sure that my profile is correct. Remember I used to get 1.99 then after you changed the SNR it went up to 2.5 and now its the worst ever at 1.77.
Message 8 of 9
(705 Views)
19-02-2014 9:24 AM
Hi Sacha,
I'm sorry to hear the problem has returned. I've run some some in-depth tests on your line which has uncovered a fault on your telephone line which is very likely going to be the cause of the problem.
I've raised a case with our suppliers to get this repaired for you. I'm expected the necessary work to have been completed by the end of the day on Friday.
Message 9 of 9
(705 Views)
