Too Slow for YouView
- Too Slow for YouView
Re: Too Slow for YouView
24-01-2015 9:26 PM
24-01-2015 11:18 PM
Sorry, but what has this got to do with the OP's problem in Aberaeron? Can we stay on topic.
Quote from: tony8436 Time is running out for my cabinet to get the upgrade and for me to be able to take advantage
Quote from: tony8436 I am on the Hollinswood exchange,
26-01-2015 8:39 AM
Many thanks for those links, it's nice to know that something is being done in this area to increase broadband speeds, but it doesn't look like it will help me for some time to come.
I've obviously made a HUGE mistake leaving TalkTalk, not only am I getting slower speeds with Plusnet but I also often get disconnected. My broadband connection was down again this morning for about 40 minutes, WHY ? The whole situation is very frustrating and I'm extremely disappointed.
Matt
26-01-2015 8:58 AM
Unknown to you, you moved from ADSL2+ to ADSL1.
Quote from: Matt53 I've obviously made a HUGE mistake leaving TalkTalk
Have you investigated your options/rights on reverting as TT do seem to be the only non-BT-based option at present.
26-01-2015 9:07 AM
26-01-2015 9:11 AM
Re options/rights on reverting to TT, what options or rights do you think may be available to me ? I certainly feel I was conned by the Plusnet advertising.
26-01-2015 9:16 AM
As they often say "if you don't ask, you don't get".
I think I've seen comments from someone else here in a similar situation that the LLU provider they left had filled their cabinets so going back wasn't even an option.
If it's something you are considering you need to check with both providers what is on offer. Politely, obviously.
When I moved from an LLU supplier to PN on BT kit I knew it would be slower (and it is) but equally that the service would still be adequate for my needs and overall more cost-effective so I am happy with that.
26-01-2015 9:32 AM
Thanks again.
AndyH,
ADSL Max Downstream Line Rate, Up to 1. Downstream Range, 0.75 to 2.5.
Fixed Rate 1
26-01-2015 9:35 AM
(worth checking the basics just in case)
26-01-2015 10:24 AM
Many thanks for helping but I'm sorry to say that when it comes to broadband technicalities I'm as ignorant as a newborn
How do I find my line stats from my router ?
Re Master socket, no I'm connected to a socket in my office, the master socket is in the kitchen by the back door. I did connect the router and my laptop to the master socket a few days ago but it made no difference to my speed when using a speed test site.
Matt
26-01-2015 10:27 AM
It's worth comparing the stats when connected to the test socket on the master socket and your extension.
26-01-2015 10:45 AM
I'll see what I can do. (this could take a while ! )
26-01-2015 10:47 AM
It wouldn't. And it would need to be the Test Socket behind the faceplate.
Quote from: Matt53 I did connect the router and my laptop to the master socket a few days ago but it made no difference to my speed when using a speed test site.
Your throughput is managed by a profile system and updating those profiles takes time (and stability) so any such quick test will prove nothing.
(The connection speed as requested by AndyH on the other hand will change)
It may be rather different (and that user is fairly technical) but you may find the outcome in this thread interesting: http://community.plus.net/forum/index.php/topic,135190.0.html
Just look at the first and last few posts for starters. This is the latest http://community.plus.net/forum/index.php/topic,135190.msg1193996.html#msg1193996
26-01-2015 11:11 AM
I suspect a bigger factor is the chipset talktalk use and their dslam configuration.
26-01-2015 12:18 PM
Hope my copy & pasting is good enough for the info you need
Office Extension.
DSL Connection
Link Information
Uptime: 0 days, 0:12:57
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,144
Data Transferred (Sent/Received) [kB/MB]: 699.40 / 2.38
Output Power (Up/Down) [dBm]: 11.8 / 17.6
Line Attenuation (Up/Down) [dB]: 31.5 / 63.0
SN Margin (Up/Down) [dB]: 11.0 / 6.0
Chipset Vendor ID (Local/Remote): BDCM / ALCB
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 5 / -
FEC Errors (Up/Down): 0 / 185
CRC Errors (Up/Down): 0 / 10
HEC Errors (Up/Down): - / 106
Internet
Connection Information
Link Status: IPv4 connected
IPv6 disconnected
Uptime: 0 days, 0:15:43
Data Transferred (Sent/Received) [MB/MB]: 1.19 / 2.21
Username:
Password:
Remember Password: Yes
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 87.114.132.226
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
TCP/IPv6 Settings
IPv6 State: Disabled
Main Socket (Faceplate Removed)
IPv6 disconnected
Uptime: 0 days, 0:14:56
2.13 / 27.94
Connection Settings
PVC Info (VPI.VCI): 0.38
Type: PPPoA
PPP Settings
Username:
Password:
Connection Mode: Always-On
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 87.113.162.166/32
IPv4 Default Gateway: 195.166.128.189
TCP/IPv6 Settings
Stateless Address Autoconfiguration:
Disabled
IPv6 Address:
IPv6 Default Gateway:
Local Interface ID:
Remote Interface ID:
IAPD Prefix:
DNS Server 1:
Link Information
Uptime: 0 days, 0:26:40
448 / 2,048
2.30 / 31.68
11.9 / 17.4
31.5 / 62.5
SN Margin (Up/Down) [dB]: 14.0 / 6.1
TMMB / ---
BDCM / ALCB
0 /
0 /
0 /
4 /
FEC Errors (Up/Down): 0 / 205
CRC Errors (Up/Down): 0 / 4
HEC Errors (Up/Down): - / 9
