Tiscali LLU
- Tiscali LLU
Tiscali LLU
13-04-2009 4:49 PM
Re: Tiscali LLU
13-04-2009 4:55 PM
Mark
Re: Tiscali LLU
13-04-2009 5:01 PM
The transition should be pretty smooth, and I am sure that Plusnet will advise you of any changes made to your connection
I hope this answers your question.
PS - I'm a moderator, not a member of Plusnet staff
Re: Tiscali LLU
13-04-2009 5:04 PM
Re: Tiscali LLU
13-04-2009 5:21 PM
Yes pierre_pierre that was the post I read about it.
Re: Tiscali LLU
13-04-2009 7:57 PM
Re: Tiscali LLU
14-04-2009 12:24 AM
Quote from: Fenster just wondered why is happening, all will be revealed no doubt.
The most likely answer is probably that Tiscali are on very shaky financial ground and there is a strong possibility of Tiscali imploding under the pressure of their half billion euro debt.
[RANT COMMING] Personally after my dealings with Tiscali two years ago the sooner that bunch of crooks go in to administration the BETTER! they deserve nothing more! [/rant over]
Re: Tiscali LLU
14-04-2009 1:00 PM
@ grudkin, I agree about Tiscali, like I said never liked that bunch, be glad to get away from them. Hope it gets sorted before they go down.
Regards,
Fenster.
Re: Tiscali LLU
14-04-2009 1:30 PM
Quote from: Fenster Hope it gets sorted before they go down.
Thats what I call wishfull thinking! LOL
Re: Tiscali LLU
14-04-2009 3:12 PM
Re: Tiscali LLU
14-04-2009 4:00 PM
I'm so glad I got out from Tiscali when I did!
Re: Tiscali LLU
14-04-2009 6:27 PM
