Ticket says downgrade !
- Ticket says downgrade !
18-12-2007 3:20 PM
I have just applied to change my BB service from PlusNet Broadband Premier Option 2 ( yep its an old one ) to PlusNet Broadband Your Way Pro with included 20GB bandwidth the new gaming one ,
But the ticket it has with it say's its a downgrade not an upgrade as I thaught it would be package itself is £1:50 cheeper than im currently paying so my question is should I change or stay with what I have as it is stable and has quite good ping times ?
Message 1 of 8
(1,725 Views)
7 REPLIES 7
Re: Ticket says downgrade !
18-12-2007 3:23 PM
I wouldn't worry about the working too much. Because it's a decrease in your subscription fees, it's classed as a downgrade. Account change would be more accurate.
You can see the expected speeds on Option 3 here.
Message 2 of 8
(621 Views)
18-12-2007 3:30 PM
Thanks for the prompt answer but its also the gaming one ive gone for with the 20gig allowance which is the same allowance I currently have ( ive got close a few times over the past few years ) but its the gaming high priority I really like .
Message 3 of 8
(621 Views)
18-12-2007 3:31 PM
Ah, sorry!
You won't do better than the Gaming product. Everything wizzes along as fast as our network will allow because of the way that all of the traffic is prioritised.
Message 4 of 8
(621 Views)
18-12-2007 4:52 PM
Again thanks for the reply looks like the move to the gaming product was the wise choice then.
Message 5 of 8
(621 Views)
18-12-2007 5:01 PM
You might want to be aware of the difference in peak/off-peak times across the two accounts.
Premier peak time is 4:00pm-Midnight whereas BBYW PRO is 8:00am-Midnight.
Message 6 of 8
(621 Views)
18-12-2007 5:22 PM
Quote from: Damfoose its also the gaming one ive gone for with the 20gig allowance .
According to the site BBYW Pro has a 10Gb allowance and not 20Gb.
http://www.plus.net/residential/broadband/alt_bbyw_pro.shtml
Message 7 of 8
(621 Views)
18-12-2007 5:45 PM
Which is correct. However Damfoose has requested an additional 10GB usage.
Message 8 of 8
(621 Views)
