Ticket response times
davidj66
Posted a question on Friday afternoon,when it was suggested response time of ~ 30 hours -is this "Mon -Friday" hours or actual hours because nothing has happened after ~ 42 hours?
reserved
Re: Ticket response times
Don't hold your breath, mine took over 48 hours for initial response  Sad
davidj66
 Ticket number 78231708 -Now over 60 hours and still waiting for it to be picked up.......I notice that Question waiting time hasn't been updated since 4th DecemberHuh Huh
I did try ringing last Friday - but as I had already spent ages on the phone trying to get thru to Tesco Customer Services ,another long wait listening to Musak didn't appeal!!!!
Fixes: 231
Hi there
Sorry for the delay in getting this picked up.
I've responded to your ticket now
 Matthew Wheeler
davidj66
Many thanks Matthew Smiley
reserved
I replied to my ticket (78128694) at 8.17pm on Friday after doing what was asked but have not had a reply!
edit: added ticket number!
Fixes: 167
@reserved
Unfortunately fault tickets often take longer to respond to, it's in the correct place for a reply and I'll check it later to make sure it's looked at today.
 Chris Parr
 Plusnet Staff
reserved
Thanks Chris. As I said in the ticket the speed has gone right up. I've done nothing my end and wonder why because I don't want to do anything to spoil it  Cheesy
reserved
Quote from: Chris
@reserved
Perhaps a nudge is needed Chris.
Fixes: 167
Are you still having issues then? I'd assumed from this comment that your speed was fine now?
 Chris Parr
 Plusnet Staff
Fixes: 167
I've just noticed that on your faults ticket you've mentioned that you sometimes get noise on the line, so I'm just running a test on the phone line.
 Chris Parr
 Plusnet Staff
Fixes: 167
That's not found any fault, so let me know if you're still seeing speed problems or whether they're sorted now.
 Chris Parr
 Plusnet Staff
reserved
Thanks Chris.
The noise is very intermittent. The speed has been very good since Saturday afternoon when I got a different ip address. I'm still on that one but just hope that the speed doesn't go down if I get on a different gateway!
Shall I close the ticket now and raise another one if the speed goes down?
Fixes: 167
It's very very unlikely to be gateway related, I think it's more likely the noise causing the issues. Next time the noise happens let me/us know and we'll run a line test to try and pin it down.
 Chris Parr
 Plusnet Staff
reserved
Thanks again Chris, I'll close the ticket & do as you suggest.
