Ticket number 47752165
Ravinella
Could someone have a look at this for me please ?
Been waiting over 24hours for a reply following an engineer visit to resolve a detected line fault.
From http://www.speedtester.bt.com/
Additional Information:
Your DSL Connection Rate :4192 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
From https://portal.plus.net/my.html?action=data_transfer_speed
Estimated line speed:
    2.0Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2011-06-11 11:38:45
Current line speed:
    0.25 Mb
From Draytek 2820n router
Mode State         Up Speed Down Speed SNR Margin Loop Att.
  G.DMT SHOWTIME 448000       4192000               16                 39
Fixes: 32
Re: Ticket number 47752165
I've submitted the line reset for you, do let us know if you need to get the phone engineer back out again.
 Adam Walker
Ravinella
Thanks, how long is it likely to take before my IP Profile gets increased to somewhere near my sync speed rather than the 135k that BT and yourselves currently have it set at ?
Fixes: 32
It usually just takes a couple of hours.
 Adam Walker
Ravinella
Thanks Adam, I'll keep an eye on it and let you know how it goes
Ravinella
That's the BT profile updated
Download speedachieved during the test was - 203 Kbps
Your DSL Connection Rate :6816 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
Could someone give the Plusnet profile a kick please as it seems to be stuck at .25Mb ?
Current line speed:
    0.25 Mb
I've updated the ticket with this request as well
jojopillo
Hi Ravinella,
I've just nudged that up to 6000 for you.
Jojo Smiley
