Ticket 88556393 Uanswered - unable to access one website
SeanP
Folks,
Not sure what's going on here - I posted a ticket but it has remained unanswered.
I am very frustrated as I am unable to access a site and forum I administrate(!) - www.rx8ownersclub.co.uk (IP 81.27.85.64) from my PlusNet home network.
Access to all other networks appears fine.
Other Site admins have checked if my PlusNet fixed IP is blocked - it isn't.
I've tried all PCs, Laptops, Mobiles, iPads & Android phones & different browsers; Wifi and Wired. Re=boot Router etc.
Checked local firewall & Internet Secutirty settings etc.
All to no avail.
All other websites appear OK.
Seems like it is blocked "somewhere" along the way - and I'd like PlusNet help to find out where & Why!
$ pathping www.rx8ownersclub.co.uk
Tracing route to rx8ownersclub.co.uk [81.27.85.64]
over a maximum of 30 hops:
0 Sean-PC.local.the-pearces.net [192.168.1.107]
1 local.the-pearces.net [192.168.1.1]
2 lo0-central10.pcl-ag02.plus.net [195.166.128.183]
3 link-b-central10.pcl-gw02.plus.net [212.159.2.166]
4 xe-10-1-0.pcl-cr02.plus.net [212.159.0.198]
5 ae1.ptw-cr02.plus.net [195.166.129.2]
6 linx236.xe-0-0-0.lucia.sov.ipv4.net.c4l.co.uk [195.66.236.201]
7 v3722.et-1-0-0.beorn.hex89.ipv4.net.c4l.co.uk [84.45.27.156]
8 beorn-hex89-ringo.c4l.co.uk [84.45.21.187]
9 ringo-swanzo.blue.net.c4l.co.uk [84.45.23.27]
10 swanzo-wolverine.blue.net.c4l.co.uk [84.45.23.24]
11 82.197.78.37
12 cg3-roobarb.c4l.co.uk [84.45.90.98]
13 84.45.13.101
14 * * *
Computing statistics for 325 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% local.the-pearces.net [192.168.1.1]
0/ 100 = 0% |
2 23ms 0/ 100 = 0% 0/ 100 = 0% lo0-central10.pcl-ag02.plus.net [195.166.128.183]
0/ 100 = 0% |
3 11ms 0/ 100 = 0% 0/ 100 = 0% link-b-central10.pcl-gw02.plus.net [212.159.2.166]
0/ 100 = 0% |
4 14ms 0/ 100 = 0% 0/ 100 = 0% xe-10-1-0.pcl-cr02.plus.net [212.159.0.198]
0/ 100 = 0% |
5 13ms 0/ 100 = 0% 0/ 100 = 0% ae1.ptw-cr02.plus.net [195.166.129.2]
0/ 100 = 0% |
6 --- 100/ 100 =100% 100/ 100 =100% linx236.xe-0-0-0.lucia.sov.ipv4.net.c4l.co.uk [195.66.236.201]
0/ 100 = 0% |
7 11ms 0/ 100 = 0% 0/ 100 = 0% v3722.et-1-0-0.beorn.hex89.ipv4.net.c4l.co.uk [84.45.27.156]
0/ 100 = 0% |
8 21ms 0/ 100 = 0% 0/ 100 = 0% beorn-hex89-ringo.c4l.co.uk [84.45.21.187]
0/ 100 = 0% |
9 17ms 0/ 100 = 0% 0/ 100 = 0% ringo-swanzo.blue.net.c4l.co.uk [84.45.23.27]
0/ 100 = 0% |
10 19ms 0/ 100 = 0% 0/ 100 = 0% swanzo-wolverine.blue.net.c4l.co.uk [84.45.23.24]
0/ 100 = 0% |
11 21ms 0/ 100 = 0% 0/ 100 = 0% 82.197.78.37
0/ 100 = 0% |
12 16ms 0/ 100 = 0% 0/ 100 = 0% cg3-roobarb.c4l.co.uk [84.45.90.98]
100/ 100 =100% |
13 --- 100/ 100 =100% 0/ 100 = 0% 84.45.13.101
Trace complete.
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: Ticket 88556393 Uanswered - unable to access one website
I get to it with no problem
This is the route
  1    17 ms    84 ms    99 ms  192.168.1.254
  2    32 ms    32 ms    32 ms  lo0.10.central10.pcl-bng01.plus.net [195.166.130
.138]
  3    32 ms    33 ms    32 ms  irb.10.pcl-cr01.plus.net [84.93.249.81]
  4    33 ms    34 ms    33 ms  ae2.pcl-cr02.plus.net [195.166.129.7]
  5    33 ms    32 ms    33 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  6    33 ms    33 ms    33 ms  linx236.xe-0-0-0.lucia.sov.ipv4.net.c4l.co.uk [195.66.236.201]
  7    33 ms    33 ms    32 ms  v3722.et-1-0-0.beorn.hex89.ipv4.net.c4l.co.uk [84.45.27.156]
  8    33 ms    32 ms    33 ms  beorn-hex89-ringo.c4l.co.uk [84.45.21.187]
  9    33 ms    32 ms    33 ms  ringo-swanzo.blue.net.c4l.co.uk [84.45.23.27]
10    43 ms    39 ms  117 ms  swanzo-wolverine.blue.net.c4l.co.uk [84.45.23.24]
11    37 ms    37 ms    38 ms  82.197.78.37
12    38 ms    37 ms    37 ms  cg3-roobarb.c4l.co.uk [84.45.90.98]
13    37 ms    38 ms    38 ms  84.45.13.101
14    38 ms    38 ms    37 ms  81.27.85.64
AndyH
@ SeanP - Are you on a static IP address with PN?
ReedRichards
Seasoned Pro
Fixes: 25
My result (with awkward line feeds removed).  Like Oldjim I have no problem loading the site.  SeanP, do you go wrong at the last hop or is that too naive an interpretation of your result?
C:\Users\RR>pathping www.rx8ownersclub.co.uk
  0  RR-PC7-64 [192.168.0.20]
  1  192.168.0.1
  2  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3  link-a-central10.pcl-gw01.plus.net [212.159.2.168]
  4  xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
  5  ae1.ptw-cr01.plus.net [195.166.129.0]
  6  linx224.ae1.vansen.the.ipv4.net.c4l.co.uk [195.66.224.201]
  7  v3721.et-1-0-0.lucia.sov.ipv4.net.c4l.co.uk [84.45.27.155]
  8  v3722.et-1-0-0.beorn.hex89.ipv4.net.c4l.co.uk [84.45.27.156]
  9  beorn-hex89-ringo.c4l.co.uk [84.45.21.187]
10  ringo-swanzo.blue.net.c4l.co.uk [84.45.23.27]
11  swanzo-wolverine.blue.net.c4l.co.uk [84.45.23.24]
12  82.197.78.37
13  cg3-roobarb.c4l.co.uk [84.45.90.98]
14  84.45.13.101
15  81.27.85.64
Computing statistics for 375 seconds...
                                0/ 100 =  0%  |
  1    0ms    0/ 100 =  0%    0/ 100 =  0%  192.168.0.1
                                0/ 100 =  0%  |
  2  27ms    0/ 100 =  0%    0/ 100 =  0%  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
                                0/ 100 =  0%  |
  3  12ms    0/ 100 =  0%    0/ 100 =  0%  link-a-central10.pcl-gw01.plus.net [212.159.2.168]
                                0/ 100 =  0%  |
  4  14ms    0/ 100 =  0%    0/ 100 =  0%  xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
                                0/ 100 =  0%  |
  5  15ms    0/ 100 =  0%    0/ 100 =  0%  ae1.ptw-cr01.plus.net [195.166.129.0]
                                0/ 100 =  0%  |
  6  ---    100/ 100 =100%  100/ 100 =100%  linx224.ae1.vansen.the.ipv4.net.c4l.co.uk [195.66.224.201]
                                0/ 100 =  0%  |
  7  12ms    0/ 100 =  0%    0/ 100 =  0%  v3721.et-1-0-0.lucia.sov.ipv4.net.c4l.co.uk [84.45.27.155]
                                0/ 100 =  0%  |
  8  12ms    0/ 100 =  0%    0/ 100 =  0%  v3722.et-1-0-0.beorn.hex89.ipv4.net.c4l.co.uk [84.45.27.156]
                                0/ 100 =  0%  |
  9  19ms    0/ 100 =  0%    0/ 100 =  0%  beorn-hex89-ringo.c4l.co.uk [84.45.21.187]
                                0/ 100 =  0%  |
10  17ms    0/ 100 =  0%    0/ 100 =  0%  ringo-swanzo.blue.net.c4l.co.uk [84.45.23.27]
                                0/ 100 =  0%  |
11  24ms    0/ 100 =  0%    0/ 100 =  0%  swanzo-wolverine.blue.net.c4l.co.uk [84.45.23.24]
                                0/ 100 =  0%  |
12  18ms    0/ 100 =  0%    0/ 100 =  0%  82.197.78.37
                                0/ 100 =  0%  |
13  17ms    0/ 100 =  0%    0/ 100 =  0%  cg3-roobarb.c4l.co.uk [84.45.90.98]
                                0/ 100 =  0%  |
14  28ms    0/ 100 =  0%    0/ 100 =  0%  84.45.13.101
                                0/ 100 =  0%  |
15  31ms    0/ 100 =  0%    0/ 100 =  0%  81.27.85.64
Trace complete.
SeanP
@AndyH - yes fixed IP from PN.
I've no doubt the website works fine & had the other admins check if my IP is blocked by the hosts or some reason - it is not.
TORPC
Quote from: AndyH
This may answer your query Wink
Quote from: SeanP
<snip>
<snip>
SeanP
Quote from: TORPC
Quote from: AndyH
Quote from: SeanP
<snip>
<snip>
I don't get you!
Yes - I have Static  IP.
Yes - The hosting site has checked if my Static IP or a block containing it are blocked. It is NOT blocked by them.
The pathping above shows 100% packet loss just on the PN border; but also by the looks of it the "last leg". I will again get the hosts to check.
Cannot understand why they would block my IP though - I'm one of the admins of said site!
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: SeanP
If by that you mean
                                0/ 100 =  0%  |
I got the same result but it didn't stop me loading your site without issues.  But I made that final hop from 84.45.13.101 to 81.27.85.64 and you don't.
Pettitto
Fixes: 5
Hi SeanP,
I can see that our Support Team have picked this ticket up now. As others from the Community, myself including can access the website, it is possible that the IP has been blocked for one reason for another. Could you contact the site administrator and double check with them?
SeanP
I've asked the other admins to raise a ticket with the Hosting provider (last time we just checked the site's own blocking, but it is "lower level" than that - because I cannot access via ssh, nor the "cpanel" admin parts either...
SeanP
Still waiting to hear feedback from the other admins... But it all seems OK now.
