Ticket #53188667 - Connection less than half of sync speed
- Ticket #53188667 - Connection less than half of s...
14-03-2012 3:04 PM
For the past week or so, I only seem to get between 4 & 6 Mb download speeds, when I'm syncing at 19,000+ (It's fluctuated a bit as I've rebooted a few times).
Initial response to my ticket was that I was only syncing at 8Mb, however that's not the case - have uploaded a screenshot showing the router sync to the ticket and also link to speedtest result.
If Jojo, Mand or any of the other amazingly helpful staff are about and wouldn't mind taking a look, it would be muchly appreciated.
Re: Ticket #53188667 - Connection less than half of sync speed
14-03-2012 3:07 PM
14-03-2012 3:10 PM
Until a week or so ago, I was seeing 19Mb+ on the BT Speedtest with no issues.
14-03-2012 3:13 PM
14-03-2012 3:14 PM
I'll post the result here for you.
Cheers,
14-03-2012 3:18 PM
14-03-2012 3:41 PM
Much improved on earlier, but still 5/6MB less than I was seeing previously.
Cheers
14-03-2012 4:56 PM
14-03-2012 5:04 PM
14-03-2012 5:09 PM
Currently seeing 3.8Mb using Speedtest.net and 4.4Mb using BT.
The earlier 13Mb result was from BT.
Edit: Just re-run using speedtest.net and I'm seeing 15Mb this time - seems to be fluctuating a lot, and even at that it's 4Mb slower than last week.
15-03-2012 9:14 AM
Your BT profile is still 16.83Mbps so you should be getting somewhere close to that. There's a couple of errors on your line too. Are you running the speed tests wirelessly or wired? How's it been performing?
Also...
Quote from: faulknerm88 Just re-run using speedtest.net and I'm seeing 15Mb this time - seems to be fluctuating a lot, and even at that it's 4Mb slower than last week.
Are you saying that you were getting 19Mbps throughput? As this would require a sync rate of 21600K and the highest your profile has been is 16.9Mbps
Jojo
15-03-2012 10:08 AM
I'm been performing everything wired, in fact with my router straight into the test socket just to rule out anything my end.
Seems fairly steady at 15.85Mb or in that region at the moment.
When I first got switched to 21CN and rebooted my router, I saw a sync of 21600, although admittedly I did not monitor what the sync speed was doing - only noticed after a connection dropout at one point that it had resync'd lower.
I was getting a stable 18,432kbps when I was downloading the newest Fedora release recently, so near enough 19Mbps throughput at that time. In fact, quite a few downloads the other week saw me maxing the connection out close to 19Mbps.
Edit: Just as a side note, despite seeing 15.85Mb through the speedtest this morning, I've just tried to set away a download of CentOS using newsgroups and am seeing no more than 4Mb throughput. If I fire up the same download on my work box (not on a PN connection) I immediately see a 27Mb d/l speed.
15-03-2012 12:00 PM
FTP/SFTP/P2P/Newsgroups/Newsgroups with SSL
A HTTP download is coming through at approx 15Mbps so seems to match the speed test results. and the other protocol downloads are at full speed on another connection when I try them.
15-03-2012 2:23 PM
Having swapped routers, it's resync'd at a slightly lower rate of 18831, however I'm still seeing a fairly stable 15.85Mb for HTTP traffic - and still a 4-5Mb for other protocol traffic.
Any suggestions greatly appreciated.
15-03-2012 3:42 PM
If you are on XP have you tuned the RWIN?
