Ticket #45903488 Calls dropping connection
adamwalker
Fixes: 221
Re: Ticket #45903488 Calls dropping connection
That sounds promising, a hawk is a testing device that phone engineers tend to use and if he's checking the wiring back to the exchange that in our opinion is what needs to be done so do let us know if you hear anything further from them. Otherwise I'll keep checking for notes on our side.
IMO I still think there's an issue at the exchange but at least Openreach are headed in that direction.
 Adam Walker
meagles79
He did say that the exchange maybe the problem but he called someone while here and was told they had a simular fault last week where the HR fault was so small he had the check the wiring all the way back , maybe he will put some copper in there on the way instead of all that ALU i have lol
meagles79
ok engineer has been back , replaced some wiring in the exchange all other wiring back to exchange is fine , we tested by calling the line and its still dropping , he has now refered it back to the exchange for an equipment change (lift and shift) i take it.
adamwalker
Fixes: 221
Thanks for the detailed update, yes I'd guess either a lift and shift or a tie pair modify could be the next step...
 Adam Walker
meagles79
i do have another pair to my house its defined as another number though. Has BT updated their side with what they are doing next?
adamwalker
Fixes: 221
I've had a report back now to say that some cabling work completed at the exchange at 14:11.  This may mean that there are outstanding tasks and that work is still underway. Just wondering if you've had the chance to test out if calls are still causing the ADSL connection to drop.
 Adam Walker
meagles79
Yes i tested about 5 mins ago , dropped out on incoming call still.
adamwalker
Fixes: 221
Nothing further has come through on the notes since my last update so I've rejected a further clear and passed the fault back. I'll continue to keep an eye on this for you.
 Adam Walker
meagles79
Ok thanks _Adam_Walker_ , i'll keep testing now and again. do you know if they are still working on the fault or is it now come to a halt for the exchange to do something.
meagles79
Morning,
Any update on what is happening regarding the fault?
Was just wondering being as BT did turn up unexpected yesterday, i don't want to be out if they do decide to make a visit again.
Mark
adamwalker
Fixes: 221
Yes, Openreach do want to arrange a visit as they've not been able to identify a fault at the exchange I'm afraid.
Can you let me know when you'd be available for this please? The slots as usual are AM = 08:00 to 13:00 or PM = 13:00 to 18:00 Mon-Fri.
 Adam Walker
meagles79
Anytime Adam, morning will be ok  , i'll be about all day though.
Mark
adamwalker
Fixes: 221
I've booked that for you, I've updated your ticket with the specifics.
 Adam Walker
meagles79
Next Monday Adam is this the best they can do , i mean they turned up yesterday within hours of the rejection and without having to book an appointment.
They are dragging their heals now because its not as clear cut as they would like or they have to replace something that will cost them money in man hours or hardware.
meagles79
Right BT called me this morning , same pstn engineer as last week ,nice bloke very helpfull, having spoke to his managers there is nothing more he can do as the line has no hr fault (as per last week) , a broadband engineer needs to be sent , plus on his notes he cannot see anything been done the exchange side??? . C'mon plusnet i have now wasted another day off.
