Throughput in the real world
- Throughput in the real world
13-01-2012 5:57 PM
Sync 16115 Plusnet IP 14M - _actual_ performance ?? 2.7Mbps
So what was the point of ADSL2+ again, exactly ?
Message 1 of 8
(1,450 Views)
7 REPLIES 7
Re: Throughput in the real world
13-01-2012 6:32 PM
Message 2 of 8
(672 Views)
13-01-2012 6:47 PM
Message 3 of 8
(672 Views)
13-01-2012 7:38 PM
@disfoot
If that test was run over a wireless connection you need to try wired.
Do you get that speed all day or just at peak times?
Message 4 of 8
(672 Views)
13-01-2012 11:59 PM
My real speed now seems to be hovering between 9M and 10M download - it's now 11:50pm.
So, not much point in having an ADSL2+ connection when the network is the bottleneck, is there ? And when the network isn't the bottleneck, then misconfigured 'Profiles' often are.
@jelv
if using wireless was also a major factor in reducing effective IP throughput, then the entire surfing population has a serious problem, as it is doubtless the preferred method of connection in preference to a CAT5 cable these days.
The problem with offering such advice to account for a drop in IP throughput from 14M to 2.7M is that it can be misinterpreted as Pro-ISP FUD. In reality, modern G and N wireless links are surely highly unlikely to account for such a drop ?
@jelv
Message 5 of 8
(672 Views)
14-01-2012 12:17 AM
That looks like exchange contention.
Wireless can give that sort of drop for various reasons including conflict with a nearby network on the same channel.
Message 6 of 8
(672 Views)
14-01-2012 12:17 AM
Are you aware that WiFi has different data rates depending on signal quality? This mean weaker the signal a different data rate is used. I can see this on my router as if report the actual speed unlike the PC which report the maximum speed of the protocol. So I see devices connected from 54mbps down to 1mbps for an Internet radio which is positioned the furthest away from the router.
Message 7 of 8
(672 Views)
16-01-2012 11:56 AM
Hi disfroot,
If you seem to be getting slower speeds at different times of the day then I would suggest raising a fault so this can be investigated further. If it turns out to be VP related it has been know for people to be moved onto different VPs.
Jojo
Jojo
Message 8 of 8
(672 Views)
