Throughput Speed
- Re: Throughput Speed
Throughput Speed
14-02-2013 5:48 PM
Can someone please explain why my download speed is allways around 9Mbps.
My sync rate is stable at 14374Kbps
My IP Profile is 12.68Mbps.
I read on the pn website Broadband terminology guide that my IP profile will always be 88.2% of the sync rate which is correct.
Throughput speed This is the actual speed you're able to download data. In normal conditions this will be close to but never higher than your current IP Profile.
Mine is stuck at 9Mbs no matter what time I test at.
Cal
14-02-2013 6:12 PM
14-02-2013 7:09 PM
9Mb (This may vary between 7Mb and 11Mb) - Checked on 2013-02-06 10:29:34
Current line speed:
12.6 Mb
14-02-2013 7:15 PM
14-02-2013 9:48 PM
18-02-2013 10:11 PM
Its like iam banded at 9Mbps
18-02-2013 10:30 PM
19-02-2013 11:50 AM
19-02-2013 2:56 PM
I tried the router in the master socket and used my laptop to check speeds which I was getting 11.4Mps
I then tried the router using the upstairs socket still getting 11.4Mps
I then tried using the ethernet cable that runs between my router and computer in the laptop and it drops to 9Mps so it would seem that my cable is bad.
I will purchase a new cable.
Cal
19-02-2013 2:58 PM
Please let us know what kind of results you are getting with a new cable.
Fingers crossed that will do the job
19-02-2013 6:04 PM
Cable changed
Before
http://www.thinkbroadband.com/speedtest/button/136129077598616179518.png
After
http://www.thinkbroadband.com/speedtest/button/136129661743530024045.png
I am happy with the results
Cal
20-02-2013 2:51 PM
