Throttling
superbin
Throttling
hi now its been sorted my internet speed is about 19mb but for past week my internet drop from 19mb to about 4mb this can happen a few times a day for example my speed is 19mb then say 20 min after do another speed test my speed is say 4mb then say i do another test 10 min later its back to 19mb so whats happening am i being capped or something?cheers for help
6 REPLIES 6
Fixes: 128
Re: Throttling
Plusnet does not throttle internet connections unless your account is in failed billing.
Which speed tester are you using and which browser?
Over wifi or over ethernet with wifi turned off?
Can you be sure that no one else and no other process is using the internet connection when you run these tests?
What time of day are you noticing this - never mind speed tests are you actually seeing any operational difficulties?
The cause of this could be any one of...
  • PC busy doing something else
  • Other applications / computer devices in your home using the internet at the same time
  • WiFi congestion
  • Variable data transmission error rates on the line cause by interference which is not quite bad enough to break the connection
  • Congestion from the exchange to the internet
  • The speed test server being overly busy
superbin
Re: Throttling
hello, i use broadband speed checker and Ookla im using ethernet my wifi is off using google crome and msn internet explorer when i doing speed tests one other person on another pc at the same time they on wifi this happens various times of the day and night i do notice web pages seem to open little slower and my ping seem little higher when my internet drops speed,thanks
adamwalker
Fixes: 204
Re: Throttling
Are you saying the speeds only drop when someone else using the connection on another device?
 Adam Walker
superbin
Re: Throttling
hello no it also happens if im just on the internet cheers
superbin
Re: Throttling
any more information that can help me thanks
MatthewWheeler
Fixes: 433
Re: Throttling
Sorry to hear you're still having problems.
Our testing hasn't identified any issues with your service.If you're still having issues please follow the steps below we can investigate further please connect your computer/laptop to the router with a ethernet cable and run the BT Speedtester service here.
You must ensure that you have no other programs running at the same time such as streaming, general browsing and the most common one is antivirus programs downloading updates in the background.
This must be done on a wired connection and not wireless Once the initial result is completed please click Further Diagnostics. Please type in your phone number and click run diagnostic test.
This will run a test and send the results to the server for investigation
 Matthew Wheeler
