Throttling me
tolmie35
Throttling me
Im already on a very poor connection, 4mb and now it seems when im downloading stuff plusnet are throttling me, im at present getting 0.5mb download, honestly whats the point in that, it already takes me ages to download stuff and then you guys make it worse.
Re: Throttling me
What package are you on, how are you downloading (Torrent or HTTP / FTP etc ?) and what does speedtest.net say while you're downloading ?
*Edit - also worth posting your router stats as well to see if it is a connection issue.
tolmie35
Re: Throttling me
Im download from Origin, it starts fine and then after a few hours my download plummets.
Re: Throttling me
What package are you on ? Unlimited or one of the other older packages ?
When your speed drops, what does speedtest.net report as your download speed ?
Re: Throttling me
It also appears you are not the only one having issues - it may not be Plusnet related :
http://www.tomshardware.co.uk/answers/id-1859788/slow-download-speed-bf4-origin.html
tolmie35
Re: Throttling me
Im on unlimited package, speedtest is not something I trust, that can be totally hit or miss depending on what server you want to ping.
tolmie35
Re: Throttling me
According to think broadband im getting 4.5mb download, its only origin thats affected, clearly being throttled, pretty annoying.
tolmie35
Re: Throttling me
It has now doubled me to 900K, woooft, still not my 4.5mb mind you., Back to 500kb argghhhhh
Re: Throttling me
But lots of other people (non - Plusnet) are also complaining about the speed from the Origin server. If they only have a finite amount of bandwidth then you will only get that download speed.
There are reports of download speeds from 0.2-0.3Mb/s from some members at certain times.
By using the speedtest.net or similar while you're downloading slowly, you can see if you have a bandwidth issue on your connection (the Speedtest result will be low) or if it could be the Origin server at fault (Origin = Slow but Speedtest = Fast).
tolmie35
Re: Throttling me
Im now running a monitor on my line. I've seen this situation many times before where ISP blame 3rd parties and vice versa, nobody ever owns up.
tolmie35
Re: Throttling me
Just checked my monitor report and I have pretty bad latency.
Re: Throttling me
I'm not saying it isn't a Plusnet issue by the way - it could well be but from the sheer number of complaints I've seen about the Origin download speeds after a quick search on their forums, it appears it may well be an EA issue rather than Plusnet.
Your latency will go up if you're uploading or downloading stuff but post the results here anyway and one of the other members who are a bit more clued up on figures may be able to shed more light on the problem.
*Edit - as for throttling by PN, they don't on the Unlimited packages. They do have traffic prioritisation which would mean if you were streaming video at the same time as downloading, the video would get priority bandwidth over the download but if you added the two bandwidth figures together, you'd still have your maximum 4.5Mb download speeds.
tolmie35
Re: Throttling me
Cannot even post the report, to slow and wont let me post it.
Re: Throttling me
Are you running any other download software ? Often using Torrents will cause lots of incoming connections which can mess up download speeds. Also maxing out your upload speed dramatically increases latency and can cause really slow download speeds.
dragon2611
Re: Throttling me
Quote from: tolmie35
Problem is it may not be Plusnet causing the slow speed, it could quite easily be congestion somewhere else or even it wouldn't surprise me if EA didn't provide enough capacity to meet the demand placed on their servers.
