Throttling effects on BBYW Option 3
- Throttling effects on BBYW Option 3
05-03-2009 7:32 PM
I've used more bandwidth than ever before this month and so i'm getting close to that point where I believe there is some throttling. I've used 22GB of the allowed 30GB and I can't find the information about when the throttling kicks in and what limitations it forces. Can someone point me in the right direction please?
Message 1 of 4
(1,035 Views)
3 REPLIES 3
Re: Throttling effects on BBYW Option 3
05-03-2009 7:47 PM
You're getting mixed up with the old Premier Option 2 product, which would become progressively throttled once someone used over 20GB of the 30GB allowance. With BBYW however, because it's designed on more of a pay-for-what-you-use basis, no special throttling kicks in after a certain amount of usage.
Message 2 of 4
(386 Views)
05-03-2009 8:34 PM
once you hit your cap(30 gb standard more if you have added it) speed 128kbps an p2p usenet are blocked all togther.
check the fixed allowence info on here http://www.plus.net/support/broadband/products/archive/bbyw/speed.shtml
Message 3 of 4
(386 Views)
06-03-2009 8:14 AM
Quote from: Be3G You're getting mixed up with the old Premier Option 2 product, which would become progressively throttled once someone used over 20GB of the 30GB allowance. With BBYW however, because it's designed on more of a pay-for-what-you-use basis, no special throttling kicks in after a certain amount of usage.
You're right, I did get the products mixed up. It's no wonder my search was fruitless! Thanks for clarifying.
Message 4 of 4
(386 Views)
