Throttled
VlNNY
Throttled
I have a contract that says between 50-80mb however im not sure how long its been going on but its actually 47-39mb... It is now consistently at this speed it looks like a typical case of throttling.. How much compo should I request as I do not know how log its been going on... My partner has been moaning for ages about my speed ...but that said she does moan a lot so I didn't take much notice... However i've done a speed test and it is slow.... Anyone else had same experience.
19 REPLIES 19
PhilipHeyes
Seasoned Champion
Fixes: 23
Re: Throttled
Speeds in the 39-47Mbps range suggest using Wi-Fi on the 2.4GHz band.
ExForce9
All Star
Fixes: 10
Re: Throttled
@VlNNY
Use the BT Broadband Availability Checker to see what range of speeds Openreach thinks your line should achieve.
Can you take a screenshot of the table of results but being careful not to include your phone number or address at the top, and then use the <Insert Photos> button in the forum editor to include the screenshot in your reply here.
Can you also take a screenshot of your router's broadband line statistics including sync speeds, SNR, attenuation, etc - but again blurring out your connection login name.  Then post that in your reply here.
These two things will give an idea to whether you have a broadband problem or a WiFi problem,
and whether you have any option to upgrade to full fibre at a higher speed.
VlNNY
Re: Throttled
Dont have any option it goes from fibre to copper into the house. maximum is 80mb.... My speed is actually 39mb.... It always been between 50-80mb... ive had this contract 10yrs...All of a sudden its now 39mb....41 is the best for 3 days... ..I have a contract saying minimum 50gb I would receive. Im ethernet to my PC and all my TVs in the house.. I do the speed test on a hard wired PC. Ive disabled 5ghz I dont sync with 2.4
Plusnet Hub Two Manager
Cheers Vince
This is a quick overview of your Plusnet Hub's status.
Connection status:
Connection type:
Fibre Broadband (VDSL)
Downstream sync speed:
47.468 Mbps
Upstream sync speed:
16.718 Mbps
Network uptime:
SixCopperKs
Re: Throttled
A Speedtest result of 41, when your modem line sync has only achieved 47, would be pretty normal. It sounds like there’s something up with your modem’s copper connection.
See if you can log into your modem, and find the advanced settings or (in the PlusNet hub system) the help desk support screen which includes a whole lot of readings. Screenshot / copy out the full DSL statistics which should include the SNR signal to noise ration for the line. Redact anything personal like your PlusNet account login name. It’s possible your full stats might reveal some fault on your analogue circuit which needs reporting to PlusNet for Openreach to resolve.
Fixes: 118
Re: Throttled
@VlNNY
I suspect your contract might actually say "estimated speed 50-80"
A view of the Checker results mentioned in post #3 would be useful.
markhawkin
Champion
Fixes: 22
Re: Throttled
@VlNNY
In the sense of an artificial restriction on the speed you receive ("throttling") that isn't happening.
The key question is what your contractual minimum download speed is.
Once you compare that to actual speed tests (with nothing else using the connection) a sensible discussion can start.
There are "physical" limitations on connection speeds using copper delivered circuits and one key factor is the condition of the copper pair (which degrades over time), another is crosstalk from other users which (perhaps due to increasing usage) seems to get worse over time.
When I had a copper (VDSL) circuit it started at around 70Mb/s download speed but in less than a decade that decreased to a bit over 50Mb/s. Fortunately in my case, full fibre arrived so that problem has gone away.
If there is an identifiable fault with the line, it should be possible to get it fixed. If it's just less good than it was then there isn't any fix until full fibre comes along.
Fixes: 480
Re: Throttled
That is not the contracted guaranteed speed. If you read your contract again it should quote a Minimum Guaranteed Access Line Speed (MGALS}. That is the figure that’s relevant.
ExForce9
All Star
Fixes: 10
Re: Throttled
@VlNNY
As you can't get "WBC FTTP" (full fibre) from Openreach,
have you checked whether you can get FTTH from an AltNet (non-Openreach) full fibre network at your address ?
If you don't know how to do this, then tell us your postcode and I'll take a look to see if anything is available in your area.
VlNNY
Re: Throttled
There's only about 25 houses in our street they said that they're not going to put full fibre in as there's not enough people. In my contract that I just read it says a speed of 50-70mb I spoke about this before agreeing. It also states that there is a guaranteed speed of 50mb ,... which i'm not getting.... I've contacted them and they have identified a fault today but I'm not sure how long this fault has been going on... Getting unhappy with PN I've just started a new contract in April but unhappy so far as its actually slower instead of being around 65mb its dropped to 55mb (thats when everything seemed to be working normally) So they're gradually dropping the speed. Time to start looking and close this account I think...Definitely not happy with the 40mb im getting at the moment.
PhilipHeyes
Seasoned Champion
Fixes: 23
Re: Throttled
@VlNNY
I read your grumbles at Plusnet, but do realise a change of ISP is going to leave you with
the exact same telephone line to the exact same street cabinet & the exact same speed.
Fixes: 118
Re: Throttled
@VlNNY
As I've already stated it would be very useful to see the Checker results mentioned in post#3
PN are not throttling your speed - you will be getting what the line can provide. At this moment, changing provider won't make any difference - you'll still be on the same line from OpenReach.
What does the OR page say for your address - www.openreach.co.uk
VlNNY
Re: Throttled
Thanks Phil..yes I came to that conclusion years ago.... However If I was getting 70mb in 2024.... and now lucky to get 50mb with plusnet maybe OReach are cutting the margins for their lines so PN are having to degrade them...Just a thought... If I can get an agreement from say BT to get back up to 70mb then Ill swap. Here is my contract from 2024 and now 2026
VlNNY
Re: Throttled
Its Openreach thanks
ExForce9
All Star
Fixes: 10
Re: Throttled
Who said that ?
So what are they going to do about it ?
@VlNNY wrote:
... they're gradually dropping the speed.
If you posted here a screenshot of your router's line stats (as asked for above),  you would have a publicly visible record of how your broadband is performing today,  so you would have evidence to show later if the speeds continue to get worse, or show the improvement if Plusnet get Openreach to repair the fault they claim exists.
By seeing the full line stats for the copper line, we should be able to diagnose what problems are currently occurring.
At the moment we have no idea whether your line has a real fault, or whether the speed has been banded to a slower speed due to a transient noise event (such as lightning or other electrically noisy event perhaps from a vehicle)
