Three Home Signal
NewGuy20
Three Home Signal
Now happily on PlusNet however I have found that my three home signal box doesn't seem to want to play anymore. I saw an article about the Vodafone equivalent but couldn't find anything about three has anyone else had a problem with one of these?
Fixes: 4
Re: Three Home Signal
Is it being blocked by the Plusnet Broadband Firewall  ?
Try switching that off, and then restarting your connection.
Michaelsobanja
works fine for me.  turn it off (unplug power) for 5 mins and then have a go. if not working then, ring the home signal people at 3 - they can do a reset.
Mike
NewGuy20
Thanks Mike,
Ill give that a try.
I've also turned off the broadband firewall and disconnected and reconnected.
Also mike out of curiosity what router do you use.
Michaelsobanja
the technicolour 582n that plusnet supplied. in fact it works better than my dlink dual band...!
Fixes: 4
[edit] Deleted - as not relevant
NewGuy20
Thanks for your help
All sorted now think it might have been the three box playing up haven't done anything and its all working this morning.
