Thomson tg585 v8 - Reset, Default Login/Password?
- Thomson tg585 v8 - Reset, Default Login/Password?
11-08-2012 1:59 AM
Greetings Forums
I am trying to login to my my Router's internal IP and Thomson Gateway is asking for a username and password. I have reset the router so the username/pass would be default? (whatever the default is?)
Thanks for any help.
Ana
Ana
Message 1 of 2
(78,745 Views)
1 REPLY 1
Re: Thomson tg585 v8 - Reset, Default Login/Password?
11-08-2012 2:18 AM
Hi AnaCrome,
The default details are:
Username: admin
Password: The serial number on the bottom of your router router. It begins with the letters CP.
Please ensure that you type the username in lower case and the password in uppercase
P.S - Welcome to the forums
Username: admin
Message 2 of 2
(32,242 Views)
