Thomson router
- Thomson router
Thomson router
02-06-2010 10:24 PM
Right I'm a new but old customer as it were. I've got 2 Plusnet accounts one back at the marital home and my new one just activated today at my new place.
So far I'm not impressed with the Thomson router, the UI is too simplistic and reminds me of the BT approach, however that is the least of my gripes.
My wireless connection keeps disconnecting. I've noticed it goes from 54Mb to 1Mb and then disconnects randomly. My Linksys which is what I expected to get is perfect.
I'd appreciate some feedback.
Message 1 of 7
(990 Views)
6 REPLIES 6
Re: Thomson router
02-06-2010 10:31 PM
It's just done it twice in the last 2 minutes!!!
Message 2 of 7
(455 Views)
Re: Thomson router
03-06-2010 9:41 AM
Are you on the latest Firmware? I had problems with wireless disconnections on 7.4.4.7. Upgrading to the latest fixed this.
See http://community.plus.net/library/uncategorized/how-to-upgradedowngrade-the-firmware-on-the-thomson-...
N.B. I think from other posts that 8.2.6.5 is the latest but I would have thought from the version numbers the latest would be 8.2.23.0.
Message 3 of 7
(455 Views)
Re: Thomson router
03-06-2010 12:01 PM
Message 4 of 7
(455 Views)
Re: Thomson router
04-06-2010 12:38 PM
I've checked the firmware and it is at the latest level.
Adam I also suspected it may be because of conflicting channels so used Netstumbler to find one not in use as there are number of other network SSID's floating around near me.
I still got disconnected last night at least once though even after choosing a new channel.
Are Plusnet only providing Thompson routers now? I'd prefer a Linksys as I'm not overly impressed with the Thompson and if I'd known I'd have probably gone out and got my own. Is there a possibilty of changing to a Linksys still?
Also can someone tell me if as it comes preconfigured does this mean someone at PlusNet is privy to my password or is a config file generated automatically? I'd be surprised if it were the latter as it would need to be created with the same password encryption algorithm used by the Thompson.
Message 5 of 7
(455 Views)
Re: Thomson router
04-06-2010 1:26 PM
Quote Also can someone tell me if as it comes preconfigured does this mean someone at PlusNet is privy to my password or is a config file generated automatically?
No, I think it uses TR-069 remote configuration to get your details from the PlusNet servers.
Message 6 of 7
(455 Views)
Re: Thomson router
04-06-2010 1:28 PM
Thanks MisterW.
Message 7 of 7
(455 Views)
