Thomson V8 firmware
- Thomson V8 firmware
- « Previous
- 1
- 2
- Next »
Re: Thomson V8 firmware
18-01-2011 8:54 AM
Quote from: ross1127 Thanks everyone, but still struggling with my first issue
Uninstall ZoneAlarm, reboot and try again.
Message 16 of 21
(434 Views)
18-01-2011 9:45 AM
When you said in your first post, "the laptop connection shows green", what exactly did you mean? It wasn't clear to me (and maybe to others).
Just a thought - it's very unlikely, but could you have a faulty ethernet cable? Do you have another cable you can try?
Graham
Graham
Message 17 of 21
(434 Views)
18-01-2011 10:42 PM
Yes i have tried a couple of cables, the green light is showing on the router and the other light is where i plug the ethernet cable into my laptop
Message 18 of 21
(434 Views)
18-01-2011 10:52 PM
Quote from: ross1127 ... the green light is showing on the router and the other light is where i plug the ethernet cable into my laptop
I think this means your router thinks you have a connection and your ethernet port thinks you have a connection. Have you uninstalled ZoneAlarm yet?
Message 19 of 21
(434 Views)
18-01-2011 11:00 PM
hav'nt unistalled z/alarm, but disabled it still no differance
Message 20 of 21
(434 Views)
18-01-2011 11:35 PM
If you open a command prompt window(*), type ipconfig /all at the prompt and press enter does the Section of the listing headed Ethernet adapter Local Area Connection show DHCP Enabled: yes, give an IPv4 address like 192.168.1.64, subnet mask 255.255.255.0 and list two DNS Servers?
* To open a command prompt window click Start, type command in the Start Search box and click Command Prompt at the top of the menu
David
Message 21 of 21
(434 Views)
- « Previous
- 1
- 2
- Next »
