Thomson V8 firmware
- Thomson V8 firmware
Thomson V8 firmware
15-01-2011 11:17 AM
Have been trying to upgrade my thomson V8 firmware, but not having very much luck, downloaded both files to do this upgrade and connected my laptop to the router (#1 connection) with the ethernet cable, the router shows a green light & the laptop connection shows green, but when i look on the thomson gateway it only shows that the laptop is connected wireless.
running vista
Re: Thomson V8 firmware
15-01-2011 12:14 PM
15-01-2011 1:16 PM
15-01-2011 2:15 PM
Has the laptop been completely restarted since the Ethernet cable was plugged in? Have you ever had the laptop connected to the router via Ethernet?
15-01-2011 5:09 PM
15-01-2011 5:55 PM
15-01-2011 6:14 PM
Quote from: ross1127 this is the first time i have tried to use a cable
It is possible to set the properties of the Ethernet port on your laptop so that it would not establish a cable connection with the router, but under the default port settings it would work. Have you never ever used a cable connection to your laptop before?
15-01-2011 6:23 PM
16-01-2011 1:02 AM
Sorry you might have posted about this in another thread but is the reason for updating the router's firmware due to intermittent problems with wireless connectivity? This post might help cure that.
16-01-2011 3:31 PM
16-01-2011 11:06 PM
16-01-2011 11:28 PM
On my Vista desktop I don't use ZoneAlarm, stuck with the Windows Vista firewall. This computer has only a wired connection to the router.
17-01-2011 7:51 AM
Quote from: ross1127 I'm running AVG/Zonealarm/Ad-Aware/Spybot-SD
That's exactly what I would have recommended six years ago but times change and things move on. AVG has got big and bloated and the current version doesn't run well on older less-powerful computers. ZoneAlarm, though it still has it's fervent supporters, isn't really necessary now we have a Windows firewall and routers with firewalls and it can get in the way now many people want home networks. Adaware I dropped as it tried to move away from the free version. Spbot-SD's technique of scanning for each bit of spyware one item at a time got overwhelmed by the sheer volume of the stuff making it very slow to complete a scan. In any case, all the former antivirus programs now also scan for spyware too, so you no longer need separate anti-spyware programs.
Sorry, this is off topic, but it just struck me that it is high time Ross1127 reconsiders what security software is appropriate.
17-01-2011 10:54 PM
18-01-2011 12:55 AM
