Thomson TG585v8 Port Forwarding
- Thomson TG585v8 Port Forwarding
31-05-2011 11:40 AM
I have recently been given a Thomson TG585v8 router by Plusnet but have had no luck trying to forward the required ports to play on PSN and EA etc. I have followed tutorials at Portforward.com but nothing seems to work. I have also tried using the DMZ function on the router, that didn't work either.
What can I do to get my ports forwarded?
Message 1 of 3
(2,181 Views)
2 REPLIES 2
Re: Thomson TG585v8 Port Forwarding
31-05-2011 11:48 AM
Have you enabled Upnp? my TG585v8 works fine with PSN.
Message 2 of 3
(322 Views)
31-05-2011 12:06 PM
Sorry, PSN does work but I get strict NAT Type on Call of Duty Black Ops and I don't connect to anyone on FIFA11. According to the FIFA11 manual I need to forward a selection of ports, I tried forwarding the ports and it made no difference. I used 'canyouseeme.org' to test the ports and every single one was still closed.
Message 3 of 3
(322 Views)
