Thomson TG585v7 orv8 plusnetrouter
- Thomson TG585v7 orv8 plusnetrouter
15-01-2012 6:12 PM
Firstly i would like to say Hello to ALL as i am a new member can anybody help? The question is, is it worth changing a Plusnet supplied router ( Thomson TG585v7 to a version 8 and if so are there any benefits ?) i'm thinking mostly from the wireless aspect
Message 1 of 6
(1,166 Views)
5 REPLIES 5
Re: Thomson TG585v7 orv8 plusnetrouter
15-01-2012 6:53 PM
/moderator hat removed
Buy a decent one - preferably wireless n with twin external aerials
/moderator hat back on
Message 2 of 6
(519 Views)
15-01-2012 6:55 PM
A variety of odd problems have been reported with the 585v8. You are better-off sticking with the 585 v7 router.
Message 3 of 6
(519 Views)
15-01-2012 8:31 PM
Quote from: Oldjim /moderator hat removed
what make type, name e.t.c. router would you recommend, and what do you use???
Message 4 of 6
(519 Views)
15-01-2012 9:02 PM
Mine is a Netgear DG834G v4 which is no longer available but I am not too bothered about wireless strength although when used with various laptops, iPhones, etc. it never gives any problems but if it ever gives up the ghost I will probably go for one of these http://www.amazon.co.uk/Billion-BiPAC-7700N-Wireless-Firewall/dp/B004WJSRN2/ref=cm_cr_pr_product_top
Message 5 of 6
(519 Views)
15-01-2012 9:40 PM
thanks for that jim, think im going to upgrade my router
jim:quote
jim:quote
Message 6 of 6
(519 Views)
