Thomson TG585v7 dropping out
- Re: Thomson TG585v7 dropping out
29-07-2013 5:14 PM
Hi all, have been having problems for a while with connection and have changed the microfilter. Have been told to now try a new router but do not have a clue which router to buy to replace it. Any advice would be much appreciated
Message 1 of 3
(957 Views)
2 REPLIES 2
30-07-2013 12:07 AM
If the Thomson router meets your needs one option is to contact support and ask for a new Plusnet TG582n router which would cost just £5.99 P & P if you are happy to stay for 12 months.
However do you require wireless capability over a long distance?
David
Message 2 of 3
(371 Views)
30-07-2013 5:58 PM
Hi thanks so much for reply, only need wireless to reach around house so that sounds brill, I will give them a call, thanks again
Message 3 of 3
(371 Views)
