Thomson TG585v7 - CLI manual anywhere?
paulh
I had one before but can't find it.
All the links I've found via google or ddg are now dead or broken.
Anyone got a live link?
I want to set up (internal only) static IPs for all my devices as SSH is moaning every time a new IP is dynamically allocated via DHCP, but you can't seem to set this via the standard interface.
Or a link to a standard non-PN firmware would be good as I believe the standard fw allows static IPs
ta
1 REPLY 1
MauriceC
Fixes: 17
Re: Thomson TG585v7 - CLI manual anywhere?
Here is a 'live' link you could try.  https://blog.bandinelli.net/public/E-DOC-CTC-20071119-0014_v2.0_public.pdf
