Thomson TG585 v8 changing routers DNS
- Thomson TG585 v8 changing routers DNS
22-01-2011 3:49 PM
Hi
I have a Thomson T585 v8 firmware 8.2.7.8 running windows 7 the DNS setting seem incorrect and I want to change them I tried the command method ref previous thread for the v7 but this didn't work as the commands weren't recognised. Is there a way to change these on the v8?
New to posting hope this makes sense.
Steve
Steve
Message 1 of 8
(10,566 Views)
7 REPLIES 7
Re: Thomson TG585 v8 changing routers DNS
22-01-2011 4:09 PM
Welcome to the forum stevewilk
Your post makes perfect sense to me unfortunately I don't use a 585 but I'm sure someone will along to assist soon
Message 2 of 8
(1,770 Views)
22-01-2011 4:20 PM
according to this http://community.plus.net/forum/?topic=91405 the commands do work
see reply 3 for an updated manual
or is that the thread you are referring to
If you follow this article where does it fall apart http://community.plus.net/library/dns/how-to-change-the-default-dns-servers-in-a-thomson-speedtouch-...
Message 3 of 8
(1,770 Views)
22-01-2011 10:05 PM
Didn't enable Telnet but now I've changed these it still shows a red cross against Connectivity to DNS Server 1 (8.8.8.8) and Connectivity to DNS Server 2 (212.159.13.49) does this matter and does adding this in IPv4 make a difference to the connection?
Steve
dick:quote
Steve
dick:quote
Message 4 of 8
(1,770 Views)
22-01-2011 10:14 PM
That seems to be a problem with that router - I have seen a few posts recently with that symptom.
http://community.plus.net/forum/index.php/topic,92451.0.html
I have no idea what the effect will be.
Of course I wouldn't have one of those routers even if it was free.
Message 5 of 8
(1,770 Views)
22-01-2011 11:50 PM
Despite showing red crosses against the DNS connectivity checks to the Plusnet DNS servers the router still provides DNS lookup as it is meant to. The problem might be that the Plusnet DNS servers don't respond to the type of probe used for the router's connectivity check.
Jojo said this was being raised with Thomson.
David
Message 6 of 8
(1,770 Views)
23-01-2011 10:45 AM
Just to make this more interesting:
I changed the DNS on my v8 and had exactly the same thing, indication of no connectivity to plusnet, google and openDNS in turn (each indicated red crosses in the test), I then tried the DNSaddresses from my laptop which runs a dynDNS client (so these would be the dynDNS servers) and then got green ticks for the entire connectivity test. I have no idea why these servers should pass the Thomson test when others do not. All the addresses I tried respond to a ping (which is a basic test of connectivity) so what is the Thomson router doing?
Call me 'w23'
Message 7 of 8
(1,770 Views)
25-01-2011 9:14 AM
HI guys, just to let you know, as Jim says there have been a few mentions of this lately which I have been taking note of. I have gathered a few examples and have our guy who deals with Thomson looking into it.
Jojo
Jojo
Message 8 of 8
(1,770 Views)
