Thomson TG585 router - port forwarding problem
- Thomson TG585 router - port forwarding problem
11-03-2013 10:14 AM
I have an Apache web server running in a virtual machine. I am using a bridged adaptor, which allows all other machines on my network to access the server successfully. However, I cannot get access from outside of my network (i.e. via the web) because the Apache server uses port 80. The Thomson router server also uses port 80, so whenever I attempt to access my web server, I get forwarded to the Thomson log in screen instead.
Is there a way to change the port which the router uses?
Message 1 of 5
(1,646 Views)
4 REPLIES 4
Re: Thomson TG585 router - port forwarding problem
11-03-2013 10:35 AM
Sounds like you've got remote access from wan enabled.
Try disabling this for HTTP:
http://npr.me.uk/remote.html
If you still wish to access the router from wan use HTTPs.
Message 2 of 5
(694 Views)
11-03-2013 11:05 AM
I checked the status of the Remote Assistance option and it is currently disabled.
Message 3 of 5
(694 Views)
11-03-2013 11:38 AM
Strange.
What result do you get from this telnet command?
service system list name=HTTP expand=enabled
Message 4 of 5
(694 Views)
11-03-2013 11:51 AM
I cracked it in the end. It was a settings issue in the router Game & Application Sharing page.
What I had to do was find the name of the VM running the web server and then assign that to the HTTP server application in the router. I also had to fiddle around with some of the VM';s network settings, but it works now.
Networking always gives me a headache!
Thanks for all the help and advice.
Message 5 of 5
(694 Views)
