Thomson Router - Help!
- Re: Thomson Router - Help!
04-12-2010 10:37 AM
I need to get to the menu to change the security settings to allow access for my blackberry...
I've tried to connect to my router using the ip address as given in the online manual
(http://192.168.1.254/)
and using Adminstrator as the username and the serial no. as the password (from rear of machine)
This isn't working - it's just possible I changed the password on installation over 12 months ago and can't remember what to - I've tried all my usual PWs. Does anyone know whether there is a way to reset it if the password has been forgotten/lost?
ta, stu
04-12-2010 10:38 AM
04-12-2010 10:47 AM
many thanks for your prompt reply (now I just have to folow another forum post to try to get the BB connected!)
04-12-2010 11:08 AM
I've tried accessing various router functions and did finally find the WAP security/config screen, but still can't find anything to change that is mentioned in another forum...
I'm just getting "failed to authenticate against the network"
04-12-2010 11:18 AM
04-12-2010 3:19 PM
05-12-2010 12:07 AM
That setting is in Home Network -> WLAN (centre screen) -> Configure (top right) - then the bottom selection box.
Don't forget to click Apply after changing the setting.
XP should support WPA2 providing it has been updated to SP3 or for SP2 if hotfix KB917021 or KB893357 has been applied. (Not relevant for me now, but I can confirm they do work.)
05-12-2010 10:50 AM
off to pull the router plug out of wall for 30 secs I think
05-12-2010 11:19 AM
windows7 machine connects OK
vista connects OK
hmmm
