Thomson Gateway unavailable
- Thomson Gateway unavailable
09-02-2019 10:44 PM
I haven't been able to access Thomson Gateway since about 9pm. Anyone else having this problem?
Re: Thomson Gateway unavailable
10-02-2019 12:07 PM
What do you mean? Is your broadband connection down or are you unable to log into your router?
on 10-02-2019 1:22 PM - last edited on 11-02-2019 9:33 AM by Mav
Hi Baldrick1, thanks for your response.
I wasn't able to log in to my router.
I had turned off WIFI and disconnected from the internet to do a power-off reset of the router. When I came back to turn it all back on again, I wasn't able to log in to the router and I had no internet connection.
After hitting the Factory Reset button I was able to log in to the router but still had no other internet connection.
Turned out that my internet log-in username and password had been changed ! ! Luckily, I had a back-up of my configuration file and was able to upload that to fix things.
I'm a bit concerned that the username and password were changed without my knowledge but I have put that down, hopefully, to a screwed up Factory Rest.
Any thoughts ?
Moderator's note by Mike (Mav): A near-duplicate post was released from Spam Filter and subsequently removed
10-02-2019 1:35 PM
It’s difficult to tell what may have happened but I’d say it’s possible that WiFi was still switched off when you turned your router back on. Doing a factory reset would’ve brought WiFi back, but also reset the username to the auto-setup one TR069@plusdsl.net (which should’ve pulled down the correct username to your router though it looks like it didn’t on this occasion until you manually configured it)
Hope this helps.
10-02-2019 2:35 PM
Thanks Gandelf, that is quite a relief in one respect.
The new username was indeed "TR069@plusdsl.net" so, at least, my router settings hadn't been hacked.
The confusing thing was that after a Factory Reset, I had expected to have to enter my log-in details again but when I selected "Plusnet Wireless" for my internet connection it went straight to "Connected" - but there was no internet access. WIFI being off was not an issue because I was using a cable connection until WIFI was back.
I did get the Plusnet initial setup page but it stuck at the "Gathering Information" page indefinitely.
I had proved the router by using a BT internet connection (at a fiver per hour) - It was a relief at not having to get a new router before getting up and running again.
I am tempted to try another Factory Reset to see what happens next time.
.Is there anything I can do to correct the Factory Reset if it all goes wrong again ?.
10-02-2019 3:25 PM
The 'connected' message was telling you that you were wirelessly connected to the router, not that the router had internet access. Why bother about testing it again, the log in details are basically the same as you use to log in to your Plusnet account apart from the @plusdsl added to your user name? The auto configuration has to be set up by Plusnet but they often forget to do it.
10-02-2019 5:42 PM - edited 10-02-2019 5:43 PM
