Thomson 585 v8 router
- Thomson 585 v8 router
27-06-2013 2:36 PM
I have a HP 650 laptop and a generic pc both running Windows 7 sp1 and having trouble with Homegroups. I can create and join and for a while my pcs remain connected but later they lose the homegroup.
Microsoft state that ipv6 must be running and it is on the laptop and pc but can my router, see subject, handle ipv6?
Thanks,
Al.
http://athome42.com
Thanks,
Al.
http://athome42.com
Message 1 of 5
(893 Views)
4 REPLIES 4
Re: Thomson 585 v8 router
27-06-2013 2:59 PM
I can't answer the question but one way round the problem is to not use homegroups but set up your own network - I have a named network running on Win 7 and XP with ip4 only
Message 2 of 5
(442 Views)
27-06-2013 3:10 PM
OK I'll give that a go, as there seems to be lots of issues with the Homegroup.
Alan
Alan
Message 3 of 5
(442 Views)
27-06-2013 3:40 PM
PlusNet don't use ipv6 unless your on the fttc package,
you can get round this by using a decent router with advanced config settings which lets you create a blind ipv6 link so everything works properly ... but it will still stop periodically and require manual reconnect or signin
Message 4 of 5
(442 Views)
27-06-2013 4:46 PM
So I guess there's no point in upgrading the router firmware then?
Alan.
Alan.
Message 5 of 5
(442 Views)
