Thomson 585 v7
craig
Thomson 585 v7
Hi the question i'd like to ask is. I've had the above router for quite some time now
Would it be worth while upgrading, I'm after better wi-fi performance.
If so could you recommend an upgrade
Don't mind purchasing one
Easy setup would be greatly appreciated
kind regards
Craig
Fixes: 68
Re: Thomson 585 v7
Hi Craig,
We can send you a Technicolor TG582n for £5.99 if you like.
 Adam Walker
Fixes: 247
Re: Thomson 585 v7
Quote from: craig
.. I'm after better wi-fi performance.
Lips are sealed
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
craig
Re: Thomson 585 v7
Adam thanks, do you think the TG582n would give improved wi-fi performance
dvorak do you mean the thomson is not very good by your reply. I don't mind the craic, as you've probably guessed my knowledge is limited to say the least.
Don't mind spending a bit of cash to get more modern equipment.
Hoping the forum could offer me a few suggestions.
regards
Craig
Fixes: 68
Re: Thomson 585 v7
I've used both and in comparison the TG582n has been much better for me personally. I don't use it any more but that's only because I decided to go for a TG589 (2 in 1 fibre modem/router)
I'd take a look around for other posts about routers here and you'll see there's a lot of opinions (some differing!) about different hardware but there's my personal and unbiased experience Wink
 Adam Walker
Fixes: 247
Re: Thomson 585 v7
i found the wi-fi performance to be less than other routers and if you look around the forums the wi-fi is the oft most complained about bit of it.
it's not a bad router in itself (certainly for the money) but as you mentioned better wifi specifically might not give you what you were looking for.
wifi also depends what your devices can handle, i've got a wireless ac access point which is great for my devices as they can use it.
craig
Re: Thomson 585 v7
Cheers guy's
my devices are iMac (2012) mac book pro retina (2013) iPad Air along with iPhone 5. I don't think either the mbp or iMac are ac enabled. I've been looking at the airport extreme but Im a little confused as to whether its a modem router or router. I've read posts on here that recommend stand alone modem, stand alone router. I'm concerned about was easy setup as reading on here again it can be sometimes be a nightmare to "newbie"
kind regards
Craig
Fixes: 247
Re: Thomson 585 v7
i've got an airport extreme.. this is plugged into a 582 in bridged mode as you are correct in your thinking that it doesn't have a modem.
you should be able to do the same with your existing router.
the mpb, air and iphone will use the 5ghz band to connect which will give you better performance than you get now.
craig
Re: Thomson 585 v7
dvorak many many thanks for that info. is there a reason why you use the 582, did you consider other modems. Is there any advantage in using a plusnet supplied device. What should I be looking for if I decided to get stand alone modem.
kind regards
Craig
Fixes: 6
Re: Thomson 585 v7
You can use your existing TG585v7 (in bridge mode) as a ADSL modem, it will be just as good as anything else.
Fixes: 247
Re: Thomson 585 v7
Quote from: craig
i'm on fibre so was using the aiport extreme on its own plugged into the fibre modem, but needed the 582 to look at something and just kind of left it there for the time being.
more of an example that you can just plug the ae into your existing router.
craig
Re: Thomson 585 v7
Really appreciate your replies guys, got an AE today. I'll let you know how I get on......
regards
Craig
