Thomson 585 v7
- Thomson 585 v7
Thomson 585 v7
03-10-2014 8:55 AM
Would it be worth while upgrading, I'm after better wi-fi performance.
If so could you recommend an upgrade
Don't mind purchasing one
Easy setup would be greatly appreciated
kind regards
Craig
Re: Thomson 585 v7
03-10-2014 9:38 AM
Re: Thomson 585 v7
03-10-2014 9:53 AM
Quote from: craig .. I'm after better wi-fi performance.
Re: Thomson 585 v7
03-10-2014 10:12 AM
dvorak do you mean the thomson is not very good by your reply. I don't mind the craic, as you've probably guessed my knowledge is limited to say the least.
Don't mind spending a bit of cash to get more modern equipment.
Hoping the forum could offer me a few suggestions.
regards
Craig
Re: Thomson 585 v7
03-10-2014 10:20 AM
I'd take a look around for other posts about routers here and you'll see there's a lot of opinions (some differing!) about different hardware but there's my personal and unbiased experience
Re: Thomson 585 v7
03-10-2014 10:20 AM
it's not a bad router in itself (certainly for the money) but as you mentioned better wifi specifically might not give you what you were looking for.
wifi also depends what your devices can handle, i've got a wireless ac access point which is great for my devices as they can use it.
Re: Thomson 585 v7
03-10-2014 10:57 AM
my devices are iMac (2012) mac book pro retina (2013) iPad Air along with iPhone 5. I don't think either the mbp or iMac are ac enabled. I've been looking at the airport extreme but Im a little confused as to whether its a modem router or router. I've read posts on here that recommend stand alone modem, stand alone router. I'm concerned about was easy setup as reading on here again it can be sometimes be a nightmare to "newbie"
kind regards
Craig
Re: Thomson 585 v7
03-10-2014 11:09 AM
you should be able to do the same with your existing router.
the mpb, air and iphone will use the 5ghz band to connect which will give you better performance than you get now.
Re: Thomson 585 v7
03-10-2014 12:13 PM
kind regards
Craig
Re: Thomson 585 v7
03-10-2014 12:23 PM
Re: Thomson 585 v7
03-10-2014 12:33 PM
Quote from: craig s there a reason why you use the 582,
i'm on fibre so was using the aiport extreme on its own plugged into the fibre modem, but needed the 582 to look at something and just kind of left it there for the time being.
more of an example that you can just plug the ae into your existing router.
Re: Thomson 585 v7
04-10-2014 6:41 PM
regards
Craig
