Thompson Gateway ERR_SSL_VERSION_OR_CIPHER_MISMATCH
B0n3s
Getting an SSL error (see attached) when attempting to configure my router using modern browser.
I can access with IE so do I need as firmware update, for modern browser support?
Product:
Thomson Gateway
Product Name: TG585 v8
Software Release: 8.2.7.8
1 REPLY 1
Fixes: 579
Re: Thompson Gateway ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Your browser is trying to tell you that your router does not support the current TLS 1.2 protocol. Versions 1.0 & 1.1 had some security issues and most modern browsers dont support them by default. Your router is quite old and Its VERY unlikey that there is a firmware update that enables TLS 1.2 support.
Options:
1) Get a more modern router that does support TLS 1.2
2) Accept the security issue and allow TLS 1.1 ( and possibly 1.0 ) in your browser if possible https://knowledge.digicert.com/generalinformation/INFO3297.html
