This shouldnt happen
daved24
Got up today and found that my internet light was RED on my modem but my internet was on so i ask you is there a problem on my line or not and do feed my aload of rubbish because i have had enough of them to last a life time.
So sort it out or i will leave plusnet and find someone else to have my connection with
i have had this problem since before Christmas and i am sick to the teeth of it now :/
bill888
Seasoned Pro
Fixes: 22
Re: This shouldnt happen
fwiw, if you are not experiencing any problems with your internet connection other than the red 'Internet' light on the router, it may be this 'bug' described here:
http://community.plus.net/forum/index.php/topic,113312.0.html/
daved24
its not just the red light on the modem i have a problem on my connetion and they dont seem to sort it out when i ring them they just tell me to log into my modem and disconnect and reconnect i admit it sometimes works but not all the time i have anouther modem and it has blocked a virus on my line but plusnet said they fix and obviusly havent
Infinity
In America, some routers show a Red light when the CIA are monitoring you, allegedly.  Lips are sealed
And the clicks on the phone line cause mini dropouts, shown as missing characters.  Cool
rongtw
Fixes: 12
off topic ,
PlusComUK nice avatar  Cool
Hi daved24,
Sorry to hear you've had a fault, I can see that we've detected no issues with your line. It might be worth us getting you a replacement router out, have you tried an alternative router at all?
daved24
i tryed my sisters talktalk router and it says it has blocked an xmas virus on my line it work for about a month then it went off too
You have been having a high number of disconnections on your line;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13679385902115.png"/>
Are you connected in your test socket?
daved24
no not connected to the test socket becoz its at the main socket is at my front door and my livingroom is at the back of my house where i am on a different socket........
And even now according to my router im not connected to the net when i clearly am............ :/
It's still disconnecting a fair bit, throughout the day. Definitely worth raising a fault but if you could test with the router in the master socket (even better the test socket) just to prove it's not your extension wiring at fault that'd be great - realise it's inconvenient and sorry about that, but the master socket test is always worth doing if only because it removes the risk of being charged if an engineer attends.
daved24
Ok I have now plugged my modem into the master socket
Have you got an active connection? Our logs are showing that the router has an incorrect password?
