turn on suggestions
This line does not have left in jumpers.
- This line does not have left in jumpers.
26-05-2015 1:23 PM
I have just done a BT check on a phone number because a friend would like fibre and apart from the usual stuff below it also said
What does that mean?
No mention was made of a cab number so is this all to do with an exchange only line
Quote This line does not have left in jumpers.
Quote WBC ADSL 2+ Up to 16 -- 8 to 19.5 Available
WBC ADSL 2+ Annex M Up to 16 Up to 1.5 8 to 19.5 Available
ADSL Max Up to 7.5 -- 7 to 8 Available
WBC Fixed Rate 2 -- -- Available
Customer and Forum Moderator.
Re: This line does not have left in jumpers.
26-05-2015 2:32 PM
Quote from: Strat I have just done a BT check on a phone number because a friend would like fibre and apart from the usual stuff below it also said
I think this basically implies that fibre hasn't been installed. Had fibre been previously installed on the line, you'd have a slightly different message.
26-05-2015 3:11 PM
Thanks Tony
26-05-2015 6:36 PM
To add to this:
It has started showing on all our order placement systems as well. All the orders we have placed have gone through ok, so I wouldn't worry too much.
26-05-2015 7:56 PM
I suspect if you cancel ,they leave jumpers until they have to be removed (say for ADSL), to save time when its reconnected(if users want fibre)
26-05-2015 11:54 PM
Now that makes a bit of sense, presumably then, the cessation fee will be abolished - it should never have been introduced, leaving jumpers until needed elsewhere should be the default.
